Possible to add auto up/down to passenger window?
Re: Possible to add auto up/down to passenger window?
Originally posted by bgruver
Just wondering if anyone has added the auto up/down feature to the passenger windows front or back?
what i really want is ONE auto up/down botton that controls all 4 windows at the same time.
I think someone talked about this a couple months ago...Something about you have to buy 3 new window buttons with the feature of the auto up/down...Do a search, I know its out there somewhere...
ok i just called the dealership about this.
they dont sell just the auto switch by itself. its the whole cluster with all four switches. so you would have to buy 3 and take it all apart. and they are $115 each!!! the part # is 254012Y910. you may be able to find it cheaper somewhere else.
The front passenger door has auto up/down in my 2k3 (as it does on the 2k2 I assume) it may be cheaper to get that side since it only has two switches, lock and auto window up/down.
Re: ...
Originally posted by GhettoMAX
D Love,
so your clifford also makes all four windows auto up/down? like the front two are on 2k2,2k3's?
D Love,
jatttaylor,
jatttaylor,
Re: Re: ...
Originally posted by D Love
Yes it does. I did have to add window modules to it though.
well DAM IT!! i just want one auto up/down switch that could control all four at the same time
yes, when you add the window modules, all 4 switches on the driver side become 1-touch up and down. even rears. and then you can also control via the remote on the alarm.
i've had this for some time now. i love it. now, if you want your rear passengers to have 1 touch up/down also for their switches, you need to run the wires to the modules to each rear door, after the w the motor, but before the switch.
it's a PITA to do, cuase it's 4 wires going to each door, 16 wires total. doable, yes, annoying, yes, but very cool to have, yes. like i said once before, i always forget to roll up my windows. this takes care of it.
i'm still in the process of having this work with the sunroof, for it to close witht he alarm.
thanks
only 2 places to go that will beat out all prices.
don aka pearl96max supplies them. you can buy them from him, even have him do the install (for a fee, of course). with him, you are beating about 90% of online prices. the only other place after that is ebay. i've seen them go for $50. online prices are from 80-100. done is somewhere int he middle.
as far as a write up is concerned, i do NOT have a write up, but given some time, i'm sure i can tell you exactly which wires go to where. you will have to open up each of your door panels if you want the rear PASSENGERS to have 1-touch. if all you care for is the the driver to have 1 touch to the rears, then you can locate the rear window wires by each kickpanel.
it is and isnt' a tough task. if you know how to distinguish + and - wires, then you can understand this. you also need to know how you're alarm is wired so that you can correctly connect to the open channels. my siren and aux buttons pressed together lower my windows. press it once, rolls down 2 inches. press again, rolls down 2 more inches, and so on. press and hold, will roll all the way down.
markevans999
Sep 10, 2015 04:29 PM
ef9
Sep 5, 2015 11:18 PM
