A question on tire pressure
Guys, i'm curious. After going aftermarket on your tires, do you still follow the tire-pressure specs as before (e.g. Nissan recommended #'s)?
Or do you follow the tire manufacturers specs?
On a similar note, to those with 18's, what PSI do you keep yours at?
Thanks.
Thanks.
Re: A question on tire pressure
Thanks.
Thanks.
Yep, i didn't know that was based on all the other factors included.
So is there a rule on how much pressure i should stay at? On the OEM Potenza's i always followed what Nissan recommended - should i use the same #'s for aftermarket rubber?
Originally posted by redstradic
i always just use the max pressure that it says on the side of tire, should you not do that?
http://www.csaa.com/global/articlede...7C2038,00.html
http://www.ridemyown.com/articles/te...idestory.shtml
Especially the second last paragraph of this...
http://home.att.net/~pdmo/safetyseven.htm
Interesting reading. Thanks for the links!
Now to get myself a digital tire pressure gauge. I still have one of those pokey $2 one's from Walgreens.
Yeah, summer is getting REALLY old!!
BTW, you have a PM.
Ok those links seem to suggest the pressure on the sidewall of the tire. My P6000s have 51 max PSI on the sidewall, Pirelli's website recomends 44 PSI and the Max says 32 PSI...Now I have no idea what pressure the tires should be at.
Ok, this might help a bit more...
http://www.tirerack.com/tires/tirete...l/pressure.htm
if in doubt, I would suggest you contact the tire manufacturer customer service line to confirm anything. make sure they take into account which vehicle you have these tires on, since the weight on each tire can vary significantly from car to car.
The proper air pressure is that where your car uses as much of the contact patch as possible, and doesnt wear onto any of the sidewall during cornering.
As for the max pressure thing, they usually say whether or not it is a cold or warm pressure. For example, I used to have a set of Energy MXV4s from Michelin. The sidewall said "44 psi Max inflation cold pressure". And I have a set of Goodyear Wrangler RS-A's on my mom's jeep that say max pressure 40psi". If it says cold, then go like 3-4 lbs lower for a cushion. If it doesnt, then keep it at like 8-10 less.
02nissmax
Sep 5, 2015 01:50 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
doobadoo
Aug 15, 2015 06:43 PM
