Went to the track.To all that say MEVI doesnt do anything in the 1/4 CLICK
Old Aug 19, 2003 | 11:14 PM
96shogunmax's Avatar
Memphis Motorsports Park
Memphis, TN
-Weather-
UV Index: 0 Minimal
Dew Point: 74°F
Humidity: 87%
Visibility: Unlimited
Pressure: 30.04 inches and rising
Wind: calm
-96 GLE 5 SPD-
JWT/ECU
MEVI
PR CAI
UR Flywheel
ACT
STS
Test Pipe
Car was fully loaded. Nothing taken out.
-Time Slip-
Was very very humid outside and nobody was doing all that well. Ran a total of 11 times. I have about 8 15.1's and a 15.0.(and a few messups).I raced my friend in his 03 SE-R specV 6spd. He couldnt get out of the 16s. That is him on the left in the time slip. His best was 16 flat. Then there was a 91-93 Mustang 5.0 that kept getting 16.xx. Something was wrong there. Another was a 300ZX that kept getting 16.xx. My previous best was 15.2 with the ECU.This is the only mod that I have added since last time. (MEVI) So here is to all the non-believers that say the MEVI doesnt do anything on the 1/4. A .3 seconds off my time works for me. Im going back when the weather gets better.
Side note - (Anybody want to sell their V1?)
Old Aug 19, 2003 | 11:31 PM
maxima_se007's Avatar
sounds like you did good. especially doing better than all of those pretty respectable cars like the 300zx, trans am, and 03 se-r. Wish I could have seen it.
Old Aug 20, 2003 | 12:11 AM
ivelweyz
Work on your 60' times and why are your RT's below .500 isn't that redlighting???
Old Aug 20, 2003 | 01:35 AM
Ceasars Chariot's Avatar
Old Maxima Legend
way to go
some places give you a yellow slip on redlights, thought it had to be in the negative ? any comments on that ?
hey 96 what were your times without jwt ecu and mevi ? just for comparison if you have them
Old Aug 20, 2003 | 05:30 AM
I30tMikeD's Avatar
It's the combo of the MEVI and the extended rev limiter. A VI w/o the JWT/ECU will not give 1/4 mile gains.
Old Aug 20, 2003 | 05:57 AM
deezo's Avatar
At least for the 5 speeds. Autos see gains.
Old Aug 20, 2003 | 06:17 AM
JAY25's Avatar
Re: Went to the track.To all that say MEVI doesnt do anything in the 1/4 CLICK
Memphis, TN
-Weather-
UV Index: 0 Minimal
Dew Point: 74°F
Humidity: 87%
Wind: calm
-96 GLE 5 SPD-
JWT/ECU
MEVI
PR CAI
UR Flywheel
ACT
STS
Test Pipe
-Time Slip-
I am glad you dont believe the hype, forget what some people say, is your car get what ever you want for it. Race a modded maxima with the regular manifold, I am willing to bet you will pull on him after 51K without the JWT ECU. With the ECU youll be so far gone it wont be funny. Dont always believe the BS, thats discussed, just try it, it is different from person to person. I mean I asked time and time again about the alloy flywheel. I am glad I did not listen and went on my own program like I usually do. Glad it worked out for you. Now your going back to a V1. Dont do it, go back to the V2, but if noise that floats your boat why not Turbo?, you can hear it spool from about a block away
Old Aug 20, 2003 | 06:26 AM
I30tMikeD's Avatar
Because of the longer gears, right?
Old Aug 20, 2003 | 06:42 AM
happyricefob's Avatar
V^___^V
yeap, also 5spd has closer gear ratio, less oppertunity for MEVI at upper rpm.
Old Aug 20, 2003 | 06:45 AM
V^___^V
again, every car is different so don't base on other's MEVI feedback upon ur max. personally i think running high 14s is a respectable number when ur fully loaded. i believe u can get down to mid 14s if u clean up a bit.
good job
Old Aug 20, 2003 | 07:03 AM
Old Maxima Legend
i think 96 will cut a bit more off too ! but he hit the 14's and thats where im trying to get. im working on my wheels at the moment and then im going to start back on the jwt ecu upgrade. some place sent me the wrong ecu, which has been a setback.
Old Aug 20, 2003 | 07:09 AM
Maxtank's Avatar
.500 is a perfect launch I think...doesn't get any better
nice times!
Old Aug 20, 2003 | 07:44 AM
dwapenyi's Avatar
Which would make sense b/c the extended rev limiter makes the 5-speed gears longer, sorta kinda like the auto, sort of
DW
Old Aug 20, 2003 | 07:47 AM
dwapenyi's Avatar
Following that thought along, an auto max with a JWT and MEVI would probably see the biggest gain NA, better than a manual, just in terms of improvement. As for that auto beating a 5-speed with MEVI and JWT, that would be very interesting to find out . . . . . . .
DW
DW
Old Aug 20, 2003 | 08:14 AM
Nealoc187's Avatar
SLOW
Alot of tracks have in the past year gone with a .000 light being perfect. It doesn't change the timing system at all, just how they write the numbers. I've raced at tracks with both timing schemes. Just makes it easier to see if you've redlighted... if your RT is negative you redlighted, if its positive you didnt.
For instance the a .250 at a track that uses .000 as perfect and a .750 R/T at a track that uses .500 as perfect are the same reaction time just expressed in a different manner.
Old Aug 20, 2003 | 08:38 AM
A .000 is perfect here. I dont have slips without the ECU sorry. And I forgot to mention I have a Y pipe. And Jaime please tell me why no V1...
Old Aug 20, 2003 | 08:59 AM
Dave B's Avatar
Not DAVEB the parts guy
DW
Well, not really. The ECU helps both the auto/5 speed because you're entering the each gear 500rpms higher which places you in the ideal spot on the shift. You're also able to run the gear 500rpms which is important because power really doesn't fall off much at 7000rpms.
Dave
Old Aug 20, 2003 | 09:01 AM
Dave B's Avatar
Congrats on the 14.9. You didn't mention the temps.
I'll be running tonight fully loaded in 100+ degree heat. We'll see if I can even get a 14.9.
Dave
Old Aug 20, 2003 | 09:16 AM
dwapenyi's Avatar
Exactly. And since autos have longer gearing than 5-speeds, they are bound to benefit more from an MEVI/JWT combo more than a 5-speed given that each gear is 500 rpms longer. I'm not saying that the auto will be faster than the 5-speed, the auto will see like say a .5 sec improvement in the 1/4 mile, whereas the 5-speed may see a .4 sec improvement. They both gain, but the auto may gain more. The 5-speed will still be faster. So, yeah, really
Anyhow, if an auto JWT MEVI would race a 5-speed JWT/MEVI, everything else being equal, there's a chance that the auto can take the 5-speed speed from top of 1st to 2nd gear, but at 3rd gear and beyond, the 5 speed will rule. Just a chance, not blow it away or anything. This is becuase I beleive that 1st gear in the 5-speed can be way too powerful and putting that power to the ground in FWD is hard. The auto has a weaker 1st gear to better spread the power.
DW
Dave
Old Aug 20, 2003 | 09:26 AM
JAY25's Avatar
your going to complain where did that extra PSI go?
smaller pulley, go with a V1 then, talk to craig mack and see if he will sell you his.
Old Aug 20, 2003 | 11:17 AM
Its just I dont like the belt shredding like it did on mine. That takes a couple of hours to fix that everytime.
I will check on the temps tonight.
Old Aug 20, 2003 | 01:55 PM
95maxrider's Avatar
Lightly modded
um, since there is a big discussion about humidity on the pet peeve thread, isn't anybody gonna coment on the 87% humidity? i though humidity that high was pretty impossible.....just curious, what would the humidity be when its raining?
Old Aug 20, 2003 | 03:25 PM
Sprint's Avatar
something is not right.. cars with less mods than that have hit lower
Old Aug 20, 2003 | 03:27 PM
JAY25's Avatar
maybe he cant drive
Old Aug 20, 2003 | 03:29 PM
Dave B's Avatar
There's nothing wrong with that humidity level assuming the temps were in lower 80s or lower. It's when people claim conditions were 90+ degrees and 90% humidity is where it's BS. 90 degrees and 50% humidity is VERY nasty and VERY humid for that kind of temp. Go back and read the links provided in that post to learn about how humidity relates to temp. Pretty much at night humidity goes up and temps obviously go down.
Dave
Old Aug 20, 2003 | 03:33 PM
Sprint's Avatar
maybe he cant drive
i would say that if his 60ft was like 2.6.. but i have seen other people such as ejj hit mid 14's with less mods on a 2.3 60ft..
i wonder what rpm he is shifting.. maybe the car just needs some new plugs and a fuel filter or maybe the ECU hasn't adjusted yet
Old Aug 20, 2003 | 04:53 PM
Requin6's Avatar
the weather, 19in.wheels(if wayne ran on those), stereo, spare, jack, full interior, maybe a little too much gas in the tank...i think 14.9 is a respectable time if the wheels and stereo and the rest that stuff were left on.
--Paul
Old Aug 20, 2003 | 06:02 PM
Old Maxima Legend
GO GET-EM DAVE !!! burn up some rubber and snag some good times !
I was thinking maybe 96 had the big rims on the car, will have to go back and check out the info ...regardless . the time was respectable and I would be proud of it .. im going to try to break into the 14's this wednesday i hope .. i just need .2
Old Aug 20, 2003 | 08:10 PM
Temp was 85 and had stock 16s on with jack and spare and full interior in the car.
Old Aug 20, 2003 | 08:12 PM
7k, and it has new plugs and fuel filter is pretty new. ECU should be adjusted
Old Aug 20, 2003 | 08:13 PM
the first run was 15.1 then the 14.9 was next. then i let air out of the tires and couldnt get traction all that well for some reason. I got like 6 or 7 more 15.1's and a 15.0
Old Aug 20, 2003 | 10:33 PM
Dev's Avatar
Dev
you should try again on a cooler, less humid day...if possible
i ran a 15.0 with intake only
then a 14.8 with ypipe and intake
so i think you could have got the same time without the mevi
Old Aug 20, 2003 | 10:49 PM
Dave B's Avatar
I ran a 14.61@94.5mph tonight in the 100 degree heat (see my other post for details). I was happy to say the least. Compared to prior runs last September with the MEVI and WITHOUT my JWT ECU in less excessive heat (lower 90s), I was ~.4 and 2.5mph faster on average tonight. The MEVI/JWT ECU is a wicked combo even when it's crazy hot.
Good luck trying to break into the 14s. You'll get there.
Dave
Old Aug 21, 2003 | 02:55 AM
Sprint's Avatar
Dave
Old Aug 21, 2003 | 08:06 AM
ejj's Avatar
ejj
I'm just a great driver!
According to his mod list, he doesn't have a y-pipe, which would just kill his top end. I'd have to trap at 95 or 96 with a 2.3 60' to get mid 14's.
Old Aug 21, 2003 | 08:33 AM
Sprint's Avatar
i am hoping he just left that out, because this thread is pointless if he doesn't even have a y pipe
Old Aug 21, 2003 | 08:41 AM
ejj's Avatar
ejj
Doh! I missed that first time reading the thread.
I dunno then. I would think a car with those mods would trap at least 95 or so, even in that humid weather.
Old Aug 21, 2003 | 09:11 AM
Dave B's Avatar
I those kind of conditions, expect your Maxima to be about .3 and 3mph slower. I've made tons of passes in hot weather and cooler 50-70 degree weather and my Maxima is a completely different animal. I'd imagine everyone else's Maximas perform about the same as mine. When ejj pulled mid 14s with a 2.3 60', it was probably much cooler out than 85 degrees with high humidity.
Dave
Old Aug 21, 2003 | 09:25 AM
ejj's Avatar
ejj
Yes. Either early spring or fall.
Old Aug 21, 2003 | 09:41 AM
I am definitly going back. The spec-v is suppose to be a mid 15 I thought? Didnt seem like nobody was doing all that well. No biggie, I will just go back after the weather cools off. It had just rained that day I went to the track hense the high humidity and right after it rained it got really hot and got the track dry enough I guess, b/c they didnt cancel it.
I had a Y pipe on
