99.4mph traps in 91 degree, 60% humidity
It was a weird night last night at the track. BriGuyMax and I30tMikeD came out to my place so we could hit the track before Brian moves to Minnesota. Right off the highway on my first 4 runs I was banging off traps of more than 99mph, 99.37 being my best. I haven't trapped higher than 98.5 since back in April when it was 45 degrees out and I was at a faster track. I was running full interior, no spare or jack. We have one run on video of myself and BriGuyMax in his 350Z on my slicks but it was a bad run for me I ran 14.4 on that one. My best run of the night was 14.13 @ 99.14 with a 2.23 60' time. I could have gotten back into 14.0s but it didn't happen.
I also got banged by an E36 M3 with intake and a chip that ran 13.95 @ 100.4 to my 14.20 @ 97.0... my MEVI didn't open on that run or something, since all my other traps for the night were above 98 and some above 99.
Originally posted by blubyu2k2
sweet what did brian and mike run? Nice times
Originally posted by Nealoc187
Brian ran 13.6 @ 101.5 on my slicks, he could have gone 13.5 but the run he did his best launch on he almost lost control of the car so he let of and ran a 14.0 @ 79mph. Mikes best run was 14.75 @ 95, we've come to the conclusion his MEVI is not opening most of the time. Mikes car weighed 3130 and mine weighed 3030 with drivers.
99 traps in those conditions are awesome
Re: 99.4mph traps in 91 degree, 60% humidity
Originally posted by Dave B
Wow, very impressive trap speeds. Were you running on your 17s, slicks, stockers? Were you running with your Cobra rotors?
You guys couldn't have raced long because wundground.com reported thunderstorms at 8pm at Bryon, IL.
Dave
Dave
My friend with hgis 350Z 6-speed and me went to track last week, his best was 14.5 at 98mph with 2.38 60ft.
It was our first time ever at the track so we need to work on launching and we should get better times.
I pulled a personal best 60', a 2.19
then missed 2nd gear
I could have ran a 14.6 or maybe even a 14.59 that run. On my 14.75 I pulled a 2.27 60'I really think my VI is no opening most of the time in 2nd or 3rd. I really should be running about .2-.3 quicker and 2mph faster. Me and neal have the same mods, granted his car is 100lbs lighter and he is a little better driver, but he really should not be a 1/2 second faster than me. I am going to check a few things like my Flex section and harlan switch to find out what's going on.
Originally posted by I30tMikeD
We were not at byron. Me and Brian went up to Michigan and ran at Neal's local track.
The 2.19 might have gotten you a 14.6. Did you change anything between this time and last time? You had mentioned you got a 14.9@93mph last time out. Looks to me like you were .2 and 2mph faster this go around and in hotter weather. Sounds like all of you were running pretty freaking good.
What kind of intake do you have? If you're running a midpipe, the switchover sound sound be very apparant. I could evne hear mine switchover last night even though I'm running a the intake resonator. If all else fails, run a toggle switch so that you can open the butterflys anytime you want. I've got mine setup like this because if I noticed my Harlan is flaking out (I've got it setup so I can see the LED), then I just hit the switch and butterflys open. No reason in blowing a pass.
Dave
What track is that?
What track is that?
The 14.9 @ 93 I told you about was last week at Rt66, I ran with my 52lb wheel tire combo that day. Yesterday I ran with Neal's millenia wheels which are a 30lb combo. I did runs with both the 17's and 15's yesteday, I ran .25 faster on the 15's.
I also just bought my own pair of millenia wheels and will mount street tires on them for now and maybe slicks next season.
I just got done wiring my harlan into the cabin of the car. later tonight, once the traffic clears up on the highways, I will make some runs to see if the switch is flaking out on me.
It always opens when I test it in nuetral, I think it just fails when it has to activate mulitple times in a row. The only time It feels or sounds like it doesn't open is 2nd or 3rd gear.
If the VI not opening isn't my problem, then I guess my car is just not all that fast.
Dave
Million-dollar question: Are you running a relay?
Dave
Dave
No, but isn't that just to make sure the harlan isn't damaged. Why would that cause it to flake out.
To answer the question posed, Brian ran 13.91 @ 100.5 at my track on his stock tires (car is still unmodded). His 60' was 2.09 if I recall.
Dave this track is much slower than byron in general. 03 Cobras trap 106ish, LS1s 6Ms trap 103-106, A 405hp z06 was there trapping 112. Last week under similar conditions I raced a Cammed GTP with 3.2 pulley and other stuff, and a GTP with Intense/ZZP rockers and 3.2 pulley and other stuff, both were trapping about 99.5.
Dave
sounds like what they run at rockingham. I have a buddy with an 01 Cobra thats spraying a 150 shot only trapping 112. He put down 440 to the wheels too. Another Cobra 03 with 449whp and 452tq trapping 113. Everyone always says my track I usually run at is so fast but I see the same times from other cars as you guys see at your local track. I have never seen a 99+ GT stang break 97-98mph either.
Dave
Well I've seen nitroused Cobras trap 115mph, but that was in 50 degree weather. The 99-01 Cobras are only capable of 105mph traps on a good day, so adding 7-9mph to that with a 120-150 shot is to be expected don't you think? The 99+ Cobras are a bit heavy (~3500lbs). I've also seen plenty of 99+ GTs go well over 100mph, but they do have NA mods and the weather was far cooler.
Dave
Dave
There was a 01 GT 5spd there with intake, exhaust, chip and pulley trapping 96-97 all day.
There was also a turbo Hayabusa that messed up his launch and still trapped 165+ it was mean. It was on a street tire and had no traction bars, just a longer swing arm.
those guys are nuts...
I've seen a couple of those busa's
That's insane!! I'd be scared sh!tless going across a 1/4mi track on one wheel at those speeds!
TKHanson
Nov 24, 2018 01:39 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
97_GXE
Sep 15, 2015 06:47 AM
