15.7 for a '03 auto Max?
I'm a first timer at the track, i have a bone stock '03 auto w/ cai. I ran 5 times and got 15.7 best (1/4 mile). Temperature was at 95-102 degrees w/ 5mph head wind. I ran against a wrx and he ran 14.1. Is 15.7 horrible? I thought my ride was lagging a bit. I wasnt sure if it was my ride or the hot temperature.
Re: 15.7 for a '03 auto Max?
Those are horrible conditions to run in for one, but those times arent good especially with a CAI. Wait unitl the temp gets better, look at my sig thats what my 03 totally stock ran but it was 80 degrees that day. Its been 100 or so here in Dallas for weeks and I can see the difference the heat and humidity are robbing my Max and 350 of power, both of us notice it.
Thats real bad. I ran at 1500 feet in 90 degree weather last time with 600 + lbs of audio last time, and I was at 15.1 - 15.3 all day . Thats with my 19's spinin all through first gear.
Re: Re: Re: 15.7 for a '03 auto Max?
It was 1121 ft above elevation at the starting line and 1200ft above at the finish line.
thats fukken crazy!! that is one uphill track....that could easily be the reason, combined with the temp and elevation. are you sure the track raises 80 feet by the finish line?
Well, first off, those times are bad for an 03 Max auto.
However, in those conditions, and considering it was your first time, I'd say, that's not too bad.
Next, if that track raises 80 feet in a 1/4 mile, I'd question who they hired to survey that track, was he/she a licensed surveyor or a high school student.
They should be as level as possible. A 10 feet increase would be acceptable but still not great.
In any case, running at 100 degrees at 1121 feet in elevation, with a 5 mph headwind, and being your first time at the track, yeah, I'd say, even if you perfected your launch, you'd be lucky to get better than a 15.4 in those conditions.
With no wind, and on a 70 degree day, you'd of probably of gotten a 15.3 with just that. Dropping yourself down to 15.0 with some experience.
If that track truly does raise 80 feet, I'd suggest two things:
1. Never go to that track again.
2. Don't tell anybody about your 15.7 time under those conditions.
Originally posted by asu174
Why does your track raise 80 feet from start to finish??!?!?!
Originally posted by MaximaSe2002
my o2 stock ran a 14.6 and it was around 70-75 degrees the second time i went it was about 95 and my worst run was a 15.1 my best was a 14.7 that day i think the problem is the track and wheels spin thats the killer
Trap Speed was at 89 mph.
AaronL
Aug 8, 2020 10:31 AM
hayne
Oct 5, 2015 11:53 AM
Maximeltman
Sep 28, 2015 07:19 PM
I have a few tricks too run a little faster wooowooo
