Dropped my car again (JICs), ran into a slight problem..
Chick specializing in rounding up 100+ Maximas
Installed JIC FLT-A2's over the weekend. Discovered that my front passenger side tire is rubbing inner wheelwell. Driver's side is fine.
Haven't done alignment yet.
I'll have the car put on lift this afternoon to check again, but it shouldn't rub. I have 2 finger wheelgap up front. I'm running 17x7.5 wheels with 40mm offset, 10mm spacers in order to clear big brakes.
Is the camber setting that off (esp. passenger side)??
Any advice is much appreciated...
AnGe
AnGe
Originally Posted by matty
alittle off the subject, but how do they ride ?
-matt
-matt
For only a low price of $403530495834095834 more than a good lowering spring/strut setup, JIC's should be the best ride quality/drop around to justify the price... I have a 2 finger wheelgap up front and mine don't rub at all? I'm running 18X7.5 wheels with 47mm offset too, so i don't think yours should rub... In fact, your wheels are ~17mm farther out than mine and the same width so it's surprising that yours are rubbing...
LEMAR
LEMAR
Originally Posted by 97MaxGurl
...with 40mm offset, 10mm spacers in order to clear big brakes...
AnGe
AnGe
You are effectively running a 30mm offset... It'll rub slightly with 235's
edit *** (driver's side rear and passenger side front, IIRC)
Originally Posted by Chunger
You are effectively running a 30mm offset... It'll rub slightly with 235's (driver's side, IIRC)
Confused is running 17x8.. 1 and half finger gap.. his wheels aren't rubbing
Ange,
235/40's would be flush (mine were on my Lowenharts) with the rim. As long as you don't use them for curb feelers it works. I switched to 245s later but am now running with 8" wide Superleggeras.
edit *** It really depends on offset... 235's with 30mm offset is like 245's with 35mm offset (like me)... and it only rubs on deep dips because I have the EXTRA travel with the MOTIVATIONAL modified Konis and upper mounts. It didn't rub without them cuz the struts use to bottom out.
Originally Posted by njmaxseltd
Congratulations AnGe, you've now had more suspension combinations in your car then I've had.
I think we need some Mud Slides to celebrate.
Chung- thanks.. hope the alignment will correct the rubbing issue a bit.
AnGe
Lakersallday24
Jun 16, 2019 01:35 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
doobadoo
Aug 15, 2015 06:43 PM
FanaticMadMax
Aug 10, 2015 08:55 PM
