I tried everything to stop my rear brakes from squealing..
They are Axxis metal master pads. I tried to lube everything and I used anti squeal compound. Should I just give up and throw the OEM back on?
sand the surface of the pads clean with garnett sandpaper (regular paper will leave deposists on the pads and cause problems later), and also do the same with the surface of the rotors, but use finer paper.
I've also used some medium grit steel wool and straight CLR cleaner to clean up the rotors with decent success. it'll remove the deposits off the iron and give you a clean surface to re-bed the pads.
The squeaks are vibrations. I believe the vibrations come from the ends of the brake pads. There should be two "ears" that each pad has so it can ride inside a channel on the caliper. It's this contact that I think makes the noise. If the "ears" are too big file them down a little. Clean the two "ears" and the corresponding caliper channels well. Then consider dabbing just a tad of high temp axle grease where you can see contact between the "ears" and caliper channel. Lots of cars have thin metallic shims that fit into the caliper channels to help with the noise vibrations.
Put a Stop squeaks compound in between 35 and 36 and also 34 and 33. This should eliminate the vibration noise problem. Aslo after sanding down your rotors, give is a good shot of brake cleaner to remove the dust particles.
You mean put that silicone rubber stuff in the channels? Won't that just goop the hell out of those areas and prevent the pads from sliding back and forth?? If it's lubricant, high temp grease is the same thing I suggested.
Any good mechanic would know what i'm talking about. The ones me and my friends has been using is either red or blue in color.
My Metal Masters were very quiet for the first 6 months, then the right rear started squealing. I tried replacing all the hardware, regreasing everything and it always came back within 2 weeks.
It's been almost 3 months since I shimmed the pads, as described above, and my brakes have been completely silent ever since. As Jeff said, noise is vibration. You need to make sure everything is snug before the caliper is placed back on.
Good luck!
Huttig2009
Sep 25, 2015 03:31 PM
RealityCheck
Aug 5, 2015 06:18 AM
