Firewall Troubles >> Urgent
PLEASE HELP ME ! I have 2 Kicker Comp VR's that are just sitting in my dynomat'd trunk because I can't find a hole in my firewall ! I am willing to drill through it but I don't know where any of the "soft spots" are and am afraid of damaging something. I know a lot of you have subs, please, just where did you route your power cable ? THANK YOU !
Where is your amp mounted?
in the trunk?
in the passenger compartment?
actually either way you can run the power through the fender into the door jamb and under the sill plate. to wherever you need to go.
Just sleeve the wire when you go through the fender.
in the trunk?
do yourself a favor and drill a hole in the firewall. dont need to burn up ur car or crimp a expensive power cable. the best place in your car i think might be towards the top on the drivers side. i worked on one max and i was able to get just behind or to the right of the clutch. on mine(1990 se) i had to put the Holes next to the slave cylinder for the clutch(real tight spot) but i was able to run 2, 0 gauge cables. i help run a sterio shop and i am almost always able to drill all the holes for the power wires on the drivers side under the dash. but on maxima, always even on the 2004's
oh yea never forget the plastic grommet = $0.20
fastcarny
Oct 12, 2015 07:06 AM
