Wide wheels on the Maxima....
Old Oct 19, 2003 | 02:45 PM
1FSTMAX's Avatar
Is it possible to run wide tires on the rear of the Maxima? If so do you any of you have any pictures? I know uncle max has wide wheels and tires, but I think he had to do something to make them fit. What is the widest you can put in the back?
Old Oct 19, 2003 | 02:54 PM
KLOOGY's Avatar
L33t BMW Drivah
Does this car look gey to you ??
His rear Volks are 1 inch wider than the front. Yes, it serves no purpose, but I cant see why its gey ?
Old Oct 19, 2003 | 02:59 PM
BLaZin 2k MaX's Avatar
He is saying its gay bc it serves no purpose, like it would on a mustang which the wider the wheel the better. If your looking for big do all four.
Old Oct 19, 2003 | 03:01 PM
KLOOGY's Avatar
L33t BMW Drivah
Originally Posted by slammed95
Does my sig look
It was a joke, I have 17x9 in the back.
17's..... ....No thx....we need big rims mi amigo ! ..we just use the Vq35 to make it up !
Old Oct 19, 2003 | 03:14 PM
KLOOGY's Avatar
L33t BMW Drivah
Humm,yeah, with a full interior, and 2 800 watt Fosgate amps , 2 eclipse aluminums, and a fiberglass enclosure. Spinning all through 1st gear, with a bald Nitto 555 in the front. I would say thats pretty good. Considering my best is 14.6 , im happy with that. I hope to go to a track with traction soon, and my new tires, and i know I will be in 14's no problem. Thats without my headers and ECU that im putting in soon.
I know you want your car to look like this
Old Oct 19, 2003 | 03:39 PM
KLOOGY's Avatar
L33t BMW Drivah
hopefully someday I'll downgrade to that.
Old Oct 19, 2003 | 04:01 PM
Maximam's Avatar
I have ran a 18x9 with 265/35 on the rear of my 5th gen.
Old Oct 19, 2003 | 04:30 PM
dmontzsta
hey kloogy. Ever seen those Cobra R 4 lug wheels? 5 star? Andrew just bought a set $350 they are 17x9 he is going to run 275/40/17 rear and 245/40/17 front.
My wheels are 17x8 with 235/45/17 all you really need...
Old Oct 19, 2003 | 06:29 PM
dmontzsta
Maybe all you need. I'll take all the traction I can get.
Thinking about getting 9.5" for the back with 275/40 and put the 17x9 up front.
Just remember, it slows you down more.
Old Oct 19, 2003 | 07:07 PM
Bman's Avatar
Yeah I really don't see the point of putting a huge wheel/tire combo out in the back of our cars. On RWD cars they're there for launch traction mainly. You'll probably be limited more by the front tires before you can take advantage of the rears...
Is it possible to tune the rear suspension of 4th Gens for a lot more oversteer? Then I could see a purpose I suppose. Just me guessing though.
Old Oct 19, 2003 | 09:03 PM
gkstar's Avatar
for more oversteer, you need to use a smaller width tire in the rear. or crank up the rear spring rates. the larger rear tires wouldn't help oversteer control, they have no power to them. no way to modulate throttle in loss of traction situation.
Old Oct 19, 2003 | 09:43 PM
gkstar's Avatar
hope the new rubber helps. just a suggestion slow down a smidge on the corner next time. There is a limit, no matter the amount of rubber in contact with the road, that the chassis can take. elimate body roll = neutral handling. wheels look sweet btw.
Old Oct 19, 2003 | 09:56 PM
KLOOGY's Avatar
L33t BMW Drivah
Damn bro... youre making it sound like your dropping a 383 stroker there, or a 428 SCJ.... you will have enough traction. Remember, its only a 3.0.....
Old Oct 19, 2003 | 10:01 PM
dmontzsta
You want to line them up a Fontana to see how much it slows me down?
I recently spun out on a mountain road going 80mph. The rear end started drifting toward the end of a turn, and it slowy went into the dirt shoulder and it was over. That's good enough reason to run the widest tires I can fit.
As long as the suspension setup is well balanced, you can't have too much grip.
Sure we can line them up at Fontana, I will line it up with anyone. I dont really have much to prove cause we all know my old engine.
I am not going to speculate on the mountain accident, cause I dont know the details, but there are other things you can do to help out, SFC's would be a big improvement as well as sways (I dont know if you have those?). Just remember, you are modding a fwd 3,000lb car, you cannot make it handle like a race car, the front wheels break loose in a turn, you are screwed. Just be safe out there and try not to push your car to the limits.
Old Oct 22, 2003 | 02:38 PM
Uncle Max's Avatar
I didn't modify anything. I just bolted them on. it was +35 offset
This helped the slowing down part =)
It's getting close woohoo
Old Oct 22, 2003 | 05:57 PM
drewm's Avatar
Don: I have maxspeeds, AGX's, FSTB, And Stillen RSB. SFC's in the near future, and maybe JIC's.
About the spinning out on the mountain. A lot of people tend to shift their stillen sway bar too far forward and will get a lot of oversteer. If you bar is in front of the rear beam, be prepared for HEAVY oversteer. It's just a fact of putting it to far forward, if you don't know how to drive a heavily oversteering monster, set the bar farther back. This is especially important on downhill corners, your rear is a lot more likely to come out unless you keep on the gas the whole time. Chebosto had the same problem when he spun out, his stillen was way far forward and he was on a downhill corner.
Personally, I get enough off throttle oversteer with my bar set slightly behind the rear beam.
Old Oct 22, 2003 | 09:59 PM
BLKMAX005SPD's Avatar
I like that gray max...those rims are tight
i love the lip
what size is the rear?
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
Cipitiox
Wheels/Tires
Sep 30, 2015 06:16 PM
Andy29
Sep 29, 2015 05:32 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
Redfox
Sep 28, 2015 10:41 AM
