Anyone replace Knock Sensor without getting code
yeh, was out of spec and didnt store a code and cost like over a second in the 1/4 mile. if its out of spec try bypassing it with a 550k resistor. if your performance comes back either leave it that way or buy another knock sensor.
Originally Posted by chillinmax
didnt get a CEL, but found symptoms of a bad sensor...
-sluggish low rpms...shi.tty gas mileage.
i just got it put in. acceleration is back; dont knwo about mileage yet
where is the KS located at.... My car was in an accident after i got it fixed it ran fine for about 2 weeks then started running sluggish an givin really F***ed up gas milage..... an how hard is it to change?
Well, I replaced my knock sensor a few hours ago. I didn't have a code but ran horrible times at the track (I have pretty much every bolt on mod) the last time so I figured it was the KS.
After finally getting it in I went for a long drive.
I noticed that my CAI is much louder and my low end pulls much harder. Before, the car lagged up until about 4000-4500rpm. Feels much smoother and more powerful.
Can't wait to hit the track again and see what my car really runs.
-Tony
-Tony
-Tony
-Tony
I didn't check for anything or test the KS. I just read so many posts about guys running a second too lsow in the quarter mile and then changing their knock sensor and that being the trick. I knew everything on my car was in perfect shape except i wasnt sure about the KS. I took a chance by replacing it and it worked out for me.
-Tony
-Tony
ARAFFIO you will probably notice that after a week or 2 the performance will get slightly worse than it is now. I noticed that whenever I put in a different resistor,or even the bad KS, the car feels much stronger at first and then goes back to it's old ways. Now since you actually replaced it with a good KS the decrease should be barely noticeable if at all...
Originally Posted by I30tMikeD
I can see it now, dozens of org members replacing perfectly good knock sensors.....
Last year I got the knock sensor code. I checked the sensor with a multimeter and I confirmed the sensor was bad. I also inspected the knock sensor harness because that has been known to fail and cause knock sensor CELs.
Way to many people on this Org blindly replace good parts with no other reason than because of something they read in a post. Being able to use a multimeter ($20) and a Hayne's/Chilton's manual ($18) will allow you to truely see if any of your sensors are indeed faulty. It's not brain surgery. The misinformation on the Net is overwhelming. You need to make you're own informed decisions, not just what some other guy tells you because it worked for him.
Dave
-Tony
-Tony
Dave
Well here's my story:
Back in January and February I ran my max numerous times at the track with the intake/ypipe and a (suspected) knock sensor. I didn't know for sure because there was no cel. It felt really sluggish esspecially at the lower rpms and a downshift to 2nd from 40mph(4krpm) felt extremely torqueless. My best time was a 15.5 @ 88mph. My avg was a 15.7-15.8 with a 2.3-2.4 launch.
After changing my ks.......
It felt like a different car. Low range power was really strong and when I step on the gas in any gear it jumps without hesitating or lagging. So I headed to the track( this was around April) and my first run was a 15.0 @ 92!!! with my heavy 17" rims. My best time so far is a 14.762 @ 93.5mph with just i/y.
So just changing the ks took off .8 second from my 1/4 mile time.
-Paul
-Paul
Originally Posted by Dave B
Have you ever run your car before? Was it the same track? What were conditions like? How were your 60 foots? Hopefully you've considered all these factors before replacing a part that most likely wasn't the cause of your problems. Just by looking at your car and you're mods, it looks like you're hauling around quite a bit more weight than stock. The rims and all the stereo/TV stuff probably is making your car run high 15s to low 16s@85-87mph with high 2.3 to low 2.4 60 foots. Lots of weight and the autos poor gearing really hurt it's 0-40mph performance. The 1/4 mile is all about how hard you can get off the line.
Dave
Dave
You made a very valid point above and you are most likely correct about the track times. LOL. Except I dont have heavy stereo stuff....everything else was pretty much right on.
I am buying some 11lb Millenia wheels with Nitto drag radials to run with next time. I will also empty the trunk and back seat and convert the CAI to hybrid for the day. We'll see how it goes....5-speed in January will certainly help my times too, lol.
-Tony
Yep, people believe that replacing the knock sensor is somehow the "holy grail" of restored power. Sluggish power till 4000rpms doesn't really sound like the knock sensor because the engine is more prone to knock in the higher rpms (4000+rpms), not lower rpms unless you're lugging the motor up a long hill is too high a gear.
The effect of a faulty knock sensor is going to be felt most at the engine loads and rpm range that we drive in the most, i.e. low load, low-mid rpm.
mrc00l88
Jan 25, 2024 01:14 PM
kjlouis
Nov 24, 2018 06:09 AM
maxinout93
Aug 20, 2015 02:17 AM
