what rims fit on the 3rd gen?
Old Nov 7, 2003 | 07:02 PM
acidspit86's Avatar
does anyone know of other cars' rims thatll fit a 3rd gen SE? like just a list or something?
edit: rims that would look ok, not some minivan rims or anything
Old Nov 8, 2003 | 01:44 AM
foetray's Avatar
Most Asian mid sized sedan and sports car wheels should work. As long as the bolt pattern(5x114.3 metric 5x4.5 standard)is the same and the offset is about the same.
Maxima 89-present
Lexus es300 and I think is300
Mitsubishi Eclipse 95-99(not sure after that)
Old Nov 8, 2003 | 11:19 PM
Bman's Avatar
Originally Posted by foetray
Maxima 89-present
Most Toyotas will NOT fit Maximas because the third important factor, the hub bore, is too small to fit.
Try this page: http://www.discountedwheelwarehouse...._Reference.cfm
but just be warned that you should verify the info they have on there with your own research because I've seen a few things there that are incorrect.
Another common wheel that some of the older members might tell you are Mustang wheels. Do a search for this in the 3rd Gen forum as there is quite a bit of info on this.
stevesmax
Dec 17, 2020 11:57 AM
tcb_02_max
Sep 23, 2015 06:18 AM
wyobbagy
Aug 15, 2015 02:28 PM
