Can I switch my horn out?
Old Dec 2, 2003 | 01:49 AM
Maxceler8's Avatar
meh
I dunno if this subject is ok in this topic, but thought I would try here first.....
OK, I HATE the Maxima's horn....for a relatively nice, large car, it still has the cheap-sounding beep of my friend's Geo Metro. I hate that. I was wondering if they can be switched out (well, I'm sure it can, but how hard?) Also, I really don't know what other Nissan product has a better-sounding horn to swap it out with. Does it have to be a Nissan horn at all? For instance, I like the sound my bf's Taurus horn makes, nice and deep. I'm sure it would not be hard to find one of those, but is it switchable? Thanks for any ideas and help
Old Dec 2, 2003 | 04:54 AM
Scope's Avatar
Im izz sexay
Just Buy An Aftermarket Horn
Old Dec 2, 2003 | 06:54 PM
swilliams's Avatar
Assuming nobody comes along and says the horn's attached to the sunroof switch or something weird like that, you should have no problem replacing the horn with anything you'd like.
But I'd really recommend using a relay wired straight to the battery, new horn and existing horn wire and ground to ensure you don't fry something in the electronics. Now THAT would be expensive to fix!
Old Dec 3, 2003 | 12:38 AM
Maxceler8's Avatar
meh
Thanks guys for your help, will keep all that in mind
Old Dec 3, 2003 | 06:15 AM
PoLo's Avatar
2-Wheelin it...
hella supertone horns. almost direct replacements. use the stock horn wire as an activation wire to your relay. place the relay in your fuse box in FRONT of the battery. it fits nice and snug. power from battery. 3 grounds (1 from each horn and 1 from the relay) and run 2 wires from the relay to each horn.
difference = huge
loud = yes
many times, not that i did this purposely, but i've seen that when i'm driving and someone isn't looking and they tried to cross the street i've honked, they've jumepd back so scared, guess they thought an 18-wheeler was hounding them
Old Dec 3, 2003 | 08:42 AM
87MustangGT's Avatar
How much for the Hella's and where'd you get them?
Old Dec 3, 2003 | 08:50 AM
PoLo's Avatar
2-Wheelin it...
http://www.rallylights.com/hella/horns.asp
http://www.rapidparts.com/Pages/vwc004n.html
can't get much cheaper than that. they had a few group deals on these, but they ended up at $65 shipped. big woop. few bucks.
some people have made them direct swaps. as in they just took each horn wire (1 per horn) and put them respectively. some blew fuses. some didn't. others did that then wired through relay to battery and said that it sounded much louder.
i don't think it's that much harder to do with a relay. the relay fits nice and snug in the fuse box. pics below....the wires, if you know how to wire up a relay, are straight forward. battery to relay, relay to horn via split wires, relay to ground, and relay to stock horn wire (only need 1. the other is left hanging there.) then ground each horn (totals 3 grounds, including relay). i know this was a quick explanation, but i just assume most people know how to wire up a relay.
big note: use waterproof wires and connectors. you may think "ah whatever, i dont' need it" as did i and all my wires and connectors are rusted. they still work, but any day now they'll literally disintegrate. i may replace all the wiring this weekend. wouldn't take me more than i'd sayd 20 minutes for the whole job.
pics of relay in box....
Old Dec 3, 2003 | 08:32 PM
Seems like an easy swap... I wonder how the Compact Trumpet kit sounds - has 400 and 500Hz (instead of 300 and 500) horns, same wattage, but has a short & wide range instead of narrow & long... And much cheaper...
Old Dec 3, 2003 | 11:08 PM
02MaXiMa_GLE's Avatar
Does anyone happen to know how many dB the stock Horns are, and how many dB the Hellas are?...
PoLo: nice info!
G
Old Dec 7, 2003 | 08:02 PM
Maxceler8's Avatar
meh
Wow, thanks guys, I appreciate all the info and mini-writeup (pics were especially helpful! ), that helps out alot. I hope to get that switched out relatively soon then.
Old Dec 8, 2003 | 10:25 AM
jmax
That is actually a relay box so it should be a perfect fit.
gavin68
Sep 18, 2021 12:36 PM
AaronL
Aug 8, 2020 10:31 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
lrb6805
Sep 24, 2015 05:03 PM
