How to build a box(please help, its a christmas present)
Old Dec 11, 2003 | 12:29 PM
Luquire's Avatar
Hey y'all i need help with makeing a box for an xterra. It would be for 2 10" susb(alumipro). the box he has is way to small for the subs and look horrible. I am going to use particle board but about what dimensions should it be and what should the angle of the front board be. I was thinking about 15 degrees from center(reference point) or 75 degrees from the ground (reference point).i am going to place the box inbetween the wheel wells directly behind the back seat.
Old Dec 11, 2003 | 12:44 PM
Whitemax's Avatar
Disco Biscuit
Well, first, you need to know what the internal dimensions have to be as required by Alumipro. Then you need to find out how wide the space is between the wheel wells to determine the width, and figure out how tall they can be according to the hight of the back seat, or how tall you want the box to be. Then we can give you a bit more help...........
Old Dec 11, 2003 | 12:53 PM
TAPOUT's Avatar
You will lose
The first step you should take is some measurements. You also will need a calculator. Find the recommended box size from the manufacturer, and then multiply cubic feet by 1728. This is going to give you the volume of the box in cubic inches. Then divide your total by the width between the wheel wells in the truck. Then divide by the height, and you will be left with the depth. A quick example would be.....
2 cubic foot box (for both subs)
3456 cubic inches needed (internal dimensions)
If the measurement across was 37 1/2, you could only use 36 for your measurement if you use 3/4 inch thick wood. 3456/36 = 96, then you measure the height that you need, say 13 1/2 which will equal 12 internal. 96/12 = 8 so you internal depth will be 8 making the box 9 1/2 deep externally.
37 1/2 X 13 1/2 X 9 1/2 external dimensions. you can then cange the angle by making them all right angle triangles to find the change of volume. If you want to keep it simple, just make the bottom panel 2 inches longer, and the top 2 inches shorter. That will give you an angle, and not change the volume of the box. You should use some bracing, and lots of liquid nails. If this is your first box, keep it simple. For all the pros that want to tell you every little detail to follow, don't worry about it this time. Just build a good sealed box. I hope this helps.
Old Dec 11, 2003 | 01:12 PM
Whitemax's Avatar
Disco Biscuit
There is alot of freeware out on the net you can use to make the calculations MUCh easier. Boxplot, WinISP are two.
Old Dec 11, 2003 | 02:03 PM
AscendantMax's Avatar
i suggest you use MDF instead of particle board. yes it's more expensive but it'll last longer in the long run.
Old Dec 11, 2003 | 02:58 PM
asu174's Avatar
Clay Aiken has fancy genitals
1. Particle board sucks.
2. You need exact specifications from the manufacturer to tell you how much airspace is required.
3. Why do you need angles?
Old Dec 13, 2003 | 11:51 PM
polishpunk68's Avatar
do all home depot stores have MDF? i tried looking for it today and they only seemed to have particle board
Old Dec 14, 2003 | 12:29 AM
asu174's Avatar
Yes, all Home Depots should carry MDF. It's about $18 for a gigantic sheet.
Old Dec 14, 2003 | 01:19 AM
enough to build 2-3 boxes out of?
Old Dec 14, 2003 | 08:42 AM
asu174's Avatar
One, maybe two depending on size. Most likely one though.
Old Dec 15, 2003 | 07:25 AM
Luquire's Avatar
i found the specs for the speakers. Here they are
Description
Description
Impedance = 4 , RMS/Peak = 300/600
Fs = 23 Hz , Qms = 2.60, Qes = 0.27, Qts = 0.25,
Re = 4.0 Ohms, Vas = 2.8 Ft3, Xmax = 12 mm,
They are 2 10" subs. the specs i came up with for the box are as follows. They appear to be for both speakers but that cant be right.
13.031496=height ( how tall it is in the trunk
19.80= length ( from wheel well to wheel well)
8.50=depth
I this for one or two speakers. i think it is for one but whatever. I can just double it
Old Dec 15, 2003 | 07:39 AM
maxinmaxima's Avatar
I realize this is repetitive, but whatever you do, don't use particle board, tried to do that once, the sound was absolutely horrible!!
Old Dec 15, 2003 | 02:29 PM
Luquire's Avatar
I still need this last bit of help
Old Dec 15, 2003 | 06:07 PM
asu174's Avatar
What is your question?
Old Dec 15, 2003 | 07:09 PM
tedsmax's Avatar
Angles good
I usually angle the front 15-20 degrees and the back the same, like a trapazoid not a parallelogram. This will help break up any standing waves. You want to avoid building a cube. It is also good to have the width and hieght vary by about 30%.
MDF is the really fine grain particle board as opposed to the stuff with big a$$ wood chips in it. You can never use too much liquid nails!!
Old Dec 16, 2003 | 07:01 AM
Luquire's Avatar
thank you very much
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
Sep 27, 2015 08:37 AM
zmcneely13
Sep 26, 2015 02:26 PM
