Turbo+Super
Old Dec 31, 2003 | 04:27 AM
phoenix_master's Avatar
Turbo+Super
can I install a turbo Charger and a Super Charger on the same car??
Old Dec 31, 2003 | 06:19 AM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
yes, but its not worth it...please use the search fucntion
Old Jan 4, 2004 | 08:13 PM
Oblongshapes's Avatar
if you are going to do all that, why even buy a maxima
Old Jan 4, 2004 | 09:53 PM
SSR Engineering's Avatar
Yes you sure can, but is it worth it? Probably not, considering it would be hard to make them work in unison without any problems. It would take a LOT of tuning, pulley sizing, turbo sizing, manifold designs etc. in order to make it all work together.
Old Jan 4, 2004 | 10:25 PM
maximase86's Avatar
I love lamp.
Probably better off doing one or the other....or even trying twin turbo for that matter.
Old Jan 5, 2004 | 07:18 AM
Cutler's Avatar
There was a older MR2 that did it in one SCC mag, he did SC down low, TC up top and Nitrous through the whole powerband. But on maxima choose either SC or TC......
Old Jan 8, 2004 | 05:23 PM
SLC I30t's Avatar
you should just buy a civic after that question.
ok ok so that wasn't a nice reply, do you know how each works? I have found that a lot of people who ask questions like this don't really know the mechanism that makes these things spin.
Cutlr, you are going to have to provide proof of this because unless it was in the "born 2 b stoopid" I think you mis-read the article.
Old Jan 8, 2004 | 07:56 PM
mrnock's Avatar
maybe if it worked
Old Jan 8, 2004 | 09:16 PM
DA-MAX's Avatar
Originally Posted by mrnock
maybe if it worked
maybe if you donated it would smart ***
Old Jan 8, 2004 | 10:56 PM
ABK's Avatar
ABK
I don't think this would work. Supercharger would start boosting but once turbo kicks in it's just going to rip supercharger belt and **** to pieces. And yeah I think this thead needs to be closed
Old Jan 8, 2004 | 11:37 PM
mtcookson's Avatar
not sure how they went about making it work but yeah, its a RB26DETT with a supercharger on the side.
the best way to do this kind of setup actually would be using a dual aftercooler setup and have an electric clutch on the s/c (like the clutch used on your a/c pump). have the electric clutch shut off around the time the turbo is fully spooled. if you did a setup like this you could actually run some really high power since you could theoretically run a huge turbo and not worry about lag. if you got a big, high horse power turbo that didn't spool to say 4000 rpm or so you could have the s/c shut off around that rpm.
for the aftercooling it would be best to run two aftercooler. one for the s/c and one for the turbo. why? because if you were running one aftercooler and the s/c and t/c were on the same piping system the s/c would be blowing air into the turbo compressor (very very bad, its like running a t/c with no bov) and when the s/c shut off the turbo would be blowing air into the s/c. both ways you'd have some pressure loss and the huge possibility of damaging one of the components.
now that i think of it you'd almost have to have some sort of valve set up to close of and open up the different tubes because even with a dual aftercooler setup the pipes have to join somewhere and air will travel back to the turbo or s/c depending which is on. so, this would add to the cost because you would need an electronic valve system to change which pipes are flowing. the one that comes to my mind is the noweeds system which costs $419.00 http://www.noweeds.net/main.php3?primNavIndex=1&
after everything is done you'd be looking at a huge price tag which i would guess could easily reach over 6,000-7,000 dollars with the stuff you'll need. i would just stick with a turbo myself. a t3/t4 or t3/60-1 will spool quite nicely on these engines, if properly sized of course.
alright... i'm done now
Old Jan 8, 2004 | 11:53 PM
ABK's Avatar
ABK
wtf does that actually run? Two big a$$ garrets and one big a$$ SC? I got to say it again WTF
Old Jan 9, 2004 | 06:40 AM
DA-MAX's Avatar
could you explain that more??
Old Jan 9, 2004 | 07:59 AM
stephenlc's Avatar
Stoopid who lives in Houston, he works for the Quaker all motor civic. Some other *** asked another stupid question like this. He said it is too hard to tune but the hardest part is finding a supercharger and turbo that spin that the same rate.
Old Jan 9, 2004 | 09:48 AM
SLC I30t's Avatar
Ummm maybe I'm stoopid, but unless your on a motorcycle, I dont think you are going to get a S/C that spins as fast as a T/C
Old Jan 9, 2004 | 10:51 AM
stephenlc's Avatar
Thats what he said, not what I said.
Old Jan 10, 2004 | 01:18 AM
mrnock's Avatar
you're missing the point fkhead, you're telling a newbie to use the search function. and even then why in the hell would he donate just to search
im not going to reply again, i would expect more from a long time member.
Old Jan 10, 2004 | 08:02 AM
JAY25's Avatar
you can install both for kicks and be all show no go. Why on earth would you want to do that? You should buy a turbo kit and and tune the car and built the internals. The turbo kit alone will give you all the power you will ever need, trust me on that one. After you get a turbo kit you can **** can the SCer idea. I dont see it happening in no way or form. You may damage the compressors. At least for the turbo because the vortech is always blowing hard even at idle. Buy a SCer or Turbo kit, I highly doubt youd want to get all this stuff under the hood. It just wont fit, the piping wont.
