370cc injectors?
Old Jan 7, 2004 | 06:26 AM
cardana24's Avatar
Blown
370cc injectors?
when getting these injectors what all do you need? Holders? Connectors? or can I use the holders and connectors off of my 98 maxima? and what is a price I would expect to pay for a used set? Thanks for you help
Carson
Old Jan 7, 2004 | 06:38 AM
ejj's Avatar
ejj
All you need is the injectors. You may need to replace the o-rings if they're old...but that may not be necessary. Everything else is already on your car.
A set (6) usually goes for around $200-250 used. Almost $600 new.
Old Jan 7, 2004 | 08:07 AM
Redmax's Avatar
Redlinemax Owner
200 -250 where????? going price is about 300 to 350
Old Jan 7, 2004 | 08:20 AM
stephenlc's Avatar
I have seen them go for less than 200 dollars on e-bay. Does anybody think Supra and MR-2 side-feed injectors would work for our car? they look almost exactly like the maxima injector.
Old Jan 7, 2004 | 09:07 AM
cardana24's Avatar
Blown
alright thanks for the info...but I dont know where you can find them for under 600 new....I have been finding prices more in the neighborhood of 700-900 for a set....anyway, I dont want new ones after looking around a prices
Old Jan 7, 2004 | 09:14 AM
ejj's Avatar
ejj
I bought a set for an .org member for just under $200, and have seen a few sets go in the $250ish range.
Old Jan 7, 2004 | 11:35 AM
stephenlc's Avatar
You can get 555 cc or 740 cc injectors for 700 dollars.
Old Jan 7, 2004 | 11:53 AM
ejj's Avatar
ejj
Yeah, but you'll also need better (and more expensive) fuel management. I kinda doubt that the ECU can run injectors that large like it can with 370's.
Old Jan 7, 2004 | 12:29 PM
cardana24's Avatar
Blown
ok, I have a couple good leads in the appropriate 'used' and new price range...thanks
Old Jan 7, 2004 | 01:52 PM
Stephen Max's Avatar
I like the idea talked about elsewhere (which is common among the 300ZX crowd) of using 740 cc/min injectors along with splitting the intake into two legs with one leg being metered by a Z32 maf. Then you can use the oem ecu.
Alternatively, you could use 740's, a single intake metered with a Z32 maf, and use an SAFC to divide the maf signal by 2. Again, oem ecu.
Old Jan 7, 2004 | 02:40 PM
tampamax's Avatar
I know that the connectors will not work but have yet to test fit one into a rail. From the looks of both injectors it appears that the nissan injector is slightly larger in circumference. Not 100% sure though. I'll update this when i find out for sure in a week or two.
Maxboy23
55
May 1, 2025 06:09 PM
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
msellas
Sep 23, 2015 09:16 PM
