370CC injector 95 tt 300z
Old Jan 24, 2004 | 11:30 PM
jdmmax's Avatar
ok when i get my 370 injectors.
can someone tell me:
what my base fuel pressure i sould run it at?
what fuel disk do i use?
the injector sare sitting at my work right ow and i need to pay for them and install.
i just took my max and dynoed today and i got some great/but at the same time scary results.
dyno story here.
http://forums.maxima.org/showthread.php?t=280784
thanks
frank
Old Jan 26, 2004 | 06:42 AM
Stephen Max's Avatar
dyno story here.
thanks
frank
I take it you are going to run the 370's with the stock maf sensor and ecu. You'll want a base fuel pressure of about 26-27 psi. I'm not sure what fmu disk size people are using, probably something like a 3:1. Ask ejj, he has done this.
Old Jan 26, 2004 | 07:22 AM
ejj's Avatar
ejj
Yeah, I've got a 3:1 disc in there.
Old Jan 26, 2004 | 09:25 AM
jdmmax's Avatar
yes sir i will be using the stock maf and ecu. i have a 99 se-l is there any other way i can run the injectors. or sould i say effiecent way???
Old Jan 26, 2004 | 11:29 AM
I suppose the best way is to have your ecu programmed by JWT for the injectors, but that takes $600 and 7-10 weeks.
Other than that, the only thing you can do is adjust the base fuel pressure downward, use the 3:1 fmu for coarse afr adjustment, and an SAFC along with dyno-tuning for fine adjustment. You might be able to get away without the SAFC if you use an adjustable fmu, like the Cartech unit or the Vortech Super-fmu. But having the SAFC is good for other things, too, like checking TPS voltage or maf voltage.
Old Jan 26, 2004 | 11:30 AM
ejj's Avatar
ejj
Unless something's changed, JWT still doesn't offer ECU's for us 99 owners.
Old Jan 26, 2004 | 11:48 AM
I keep forgetting that. But isn't it true that the 95-96 ecu will work in the later 4th gen Maximas? Or is 99 different enough to where it won't?
Old Jan 26, 2004 | 11:53 AM
ejj's Avatar
ejj
I'm not sure.
I would guess it would screw with the odometers, are ours (98 + 99) store their information in the ECU itself.
I also think that the pinouts are different (although I'm not 100% sure about that). If that's the case we'd need an adapter, which wouldn't be impossiable.
I should try to find a 95 or 96 ECU and put it in my car and see what happens.
Old Jan 26, 2004 | 12:22 PM
jdmmax's Avatar
thats wierd when i swapped out for the spd ecu my miles still read correct.
other than that. i guess i have to use the mechanical way.
Old Jan 26, 2004 | 12:33 PM
ejj's Avatar
ejj
Yeah? I guess that info isn't stored in the ECU. Cool.
Maxboy23
55
May 1, 2025 06:09 PM
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
msellas
Sep 23, 2015 09:16 PM
