Fixed Bent Rim, now Car shakes ALOT above 50 mph
hey guys..havent posted in a while...a week ago i got a flat and tried to change, but with the freezing temps we've had up here in the NE, while trying to take off the lugnuts on the wheel, i snapped one off with the bolt tryin to press down on the wrench with my body weight...so eventually i got everything off really slowly and took it to a tire shop and my rim was bent slightly and that was the cause of air leaking
So they fix the rim and everything, weld it back to shape and say the tire is fine...however after a week or so of driving, everytime im on the highway, the car shakes like crazzzyyy anytime over 50mph, unimaginable shaking...the most around 70ish..and i dont mean a lil vibration...i mean the car feels like its gonna fall apart
so now im concerned, is this normal after trying to fix a bent rim?? is it the rim? is it that im missing one of the lugnuts?? my strut tops are actually blown too in the front but thats been like that for a few months, so it wouldnt be that cuz that didnt happen before...so wut can possibly be causing all the shaking? thanx for the help
yea , there are special places to send the rim to in order to do that. I wouldnt trust a shop with that.
I've had a simmilar problem with a bent rim as a cause of an accident, the simplest way to check if the car is shacking as a cause of the rim is to switch the front wheels with the back.
makes all the difference if the shaking is a cause of the bent rim since maxima is a front wheel drive.
Anyway, same thing happened to me and my mechanic fixed the problem by switching the front wheels with the back ones. It may not be the best sollution but it sure worked.
Just try it, it'll take u no more than an hour to switch the front rims with the back ones.
PS. not just one front rim but put both front rims to the back as for the even tire wear.
I have a bent rim the back and it still shakes I don't see how you think if you move it back it wont shake anymore? Certain tire shops can fix bent rims with a porta-power or hydraulic press with a half moon tool. Theres a shop around here that charges 20$-30$ to fix a bent rim. I suggest you find a shop to bend it back to shape. Switching rims won't work.
i would say that your shop did a ****ty job. i had this done when i bent a rim to the point where the tire bead wouldnt even stay on it and now it doesn't shake at all. it did cost me $70 tho
whoever got it done for $20-$30 got a great deal
There are a lot of things to consider here.
1. If u are missing a lug, ur tire wont seat properly. (replacing a lug is easy/cheap enough)
2. Did they balance the tire after fixing the rim? If the tire balances out u shouldnt feel anything. If it wont balance out its still bent/out-of-round.
3. Whats ur tire pressure on all 4 tires, make sure its the same I usually set mine at 32-33PSI
4. U will feel less shake if u put it on the rear, but that may not correct the problem.
-carlos
-carlos
I caught a curb doin some donuts in the snow
and the tire blew so they went to balance the new tire and couldnt because the rim was bent although in its circular pattern it didnt look out of shape it was wobblin side to side on its hub and anything over 50 gave me crazy vibrations so i changed that sucker out fast.
maximas can do donuts?
Hondarydr
Dec 30, 2024 06:15 PM
Lakersallday24
Jun 16, 2019 01:35 AM
RealityCheck
Aug 5, 2015 06:18 AM
