Stock Tails wont come out !!!
Originally Posted by DoGGy
how in gods name do u remove the stock tail lights to install red/clears??
i removed the 4 nutz on the screws and that thing is still STUCK in there. i cant take it out. how did u all do it?
ok i installed red/clears and talk about a ***** to install. red/clears are hard.
the passenger side didnt come out as good as i expected, i couldnt get it to fully attach to the body, there is a good gap in beween (unlike the drivers side that its secured sooooo tightly, u can easily tell that it goes in more than the piece on trunk). the gap on passenger side is big enough to see thru. would that cause a problem when it rains? for some reason it didnt wanna attach to the body, i dunno why. and for the plastic glue or w/e. i just put them on the body and installed the lights then i used hair dryer from inside to melt them down (dunno if it worked).
and i also got loooooooots of the glue stuck on my hand, it wont come off !
are they home made red clears?if they are maybe you didnt attach
the lens to the housing very well if this is the case heat them up
again and just push them in a little more ,it would help to heat up
the silicone to before puting them back it's alot easyer, if you bought them
try pushing a little harder in sometimes the srews dont go al the
way in
Just push em like a ****..that's what I did
Recently replace my left one. Purchased an OEM one and brought it into a shop and got it replace(i dont have tools). after installing it there seem to be a huge gap btw the trunk lights, its a bit inner and doesnt align straigth with the trunk.
Originally Posted by enjetek
i hope i run into your car on the street doggy. im usually around the northridge / chatsworth area because of friends and school so you never know. godd luck with the car and i will hopefully see you around.
-myke
-myke
lol, sterling mist with clear corners, red/clears and maxima.org stickers on side.
if u see that rollin with BOSE blasting, then u bet its me !
it can be tough as hell when it's cold out, otherwise it's relatively easy.
i've removed my tails more times than i want to count, but tried removing my inners yesterday so i could tint the reverse housing. i got all the screws out but then was unable to get the light out. i guess even though 38 degrees feels warm compared to what you're used to lately, it's still not warm enough to do some car stuff outside.
Originally Posted by CKOTuHA
Doggy, I had exactly the same thing when I installed my red/clears. I checked, there is no way I could've pushed them in more. What I did was, went to the Home Depot and bought some black foam in a roll. Cut it to exact fit with the gap between the car and the lights, then put it in with the lights. Where the gap is smaller, foam pushes in more....basically you can't even see that I have it. Because its also black like the outline of the lights. No problem with water or snow getting in. I recomend you to do the same unless you figured another way out of it.
smart man
Apr 16, 2020 05:15 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
