300zx MAS in a Maxima?!
But...
Originally Posted by Ramius83
It can be bought and wired up in your car for fairly cheap, but you will not see any HP gains from it.
Since most/all of the users of the 300ZX MAF are boosted, it will not help you out at all.
-Lieb-
Interesting
Originally Posted by mzmtg
The Z32 MAF is allmost 50% larger than ours (A32). This means that for a given voltage (what the ECU sees) there would be 50% more airflow. This would confuse the ECU to say the least.
Also, what is Technosquares homepage address?! Thanks.
-Lieb-
Originally Posted by Linkage23
Yeah but 300zx MAF (oops from before) are exactly the same in both the TT and NA versions. So would htis allow for more air being recognized when say you are boosted yourself?! Just seeing if there would be any benefit from an endeavor like this one.
-Lieb-
-Lieb-
How could someone apply this idea to their Max's ECU? Could a re-programer get success from this? For example JWT or Technosquare?
-Lieb-
-Lieb-
Funny thing though, someone found a shortcut. The larger injectors (cant remember which ones) could be used with the larger MAF and a stock ECU. See when a stock ECU sees a certain voltage, it gives a certain amount of fuel (in open loop mode, at WOT). Well, when both your MAF and your injectors are about 50% bigger than stock, they balance each other out. Neato.
Team STILLEN
Aug 10, 2015 04:29 PM
