Running Rich?
Old Feb 16, 2004 | 05:36 AM
Greg Qx's Avatar
Running Rich?
I have a 95 SE. The check engine light is not on. The car appears to be running very rich. When I pulled the old plugs, they were very black, but not from oil. I noticed on startup I get some black smoke, and there is a slight power loss at low rpm. Would a knock sensor cause these problems? I tend to think it wouldn't because if the sensor was bad, shouldn't it throw a code and kick the engine light on? Any input is greatly appreciated.
Old Feb 16, 2004 | 05:38 AM
mzmtg's Avatar
Minister of Silly Walks
Check the codes and get back to us.
Old Feb 16, 2004 | 05:39 AM
Greg Qx's Avatar
That's part of my question. If there was a code, wouldn't the light be on?
Old Feb 16, 2004 | 05:52 AM
njmaxseltd's Avatar
Change your o2 sensor.
Old Feb 16, 2004 | 06:49 AM
astil's Avatar
Gregg, the light would NOT be always on if there is a code. Under normal use ,the plugs shouldn t be black unless you used the wrong plug type and heat range. If you have other brand than NGK plugs, that may be your problem. The on board computer would tell you where your problem is (if any) If you don t know how to check it, get a Haynes manual. It would answer many questions that you may have now and in the future. Black smoke and black plugs may be signs of a worn engine or components.
captchaos
Mar 15, 2016 12:18 PM
msellas
Sep 23, 2015 09:16 PM
JoshG
51
Sep 21, 2015 10:41 PM
ballerchris510
Sep 10, 2015 09:35 PM
AT978
Sep 6, 2015 10:31 PM
