aerobearing turbos
aerobearing turbos
does anybody know anything about those if anybody even sells them theyre supposedly the fastest spooling turbo with little to none shaft and bearing friction and theyre really expensive
i think the company stopped making them for cars and trucks and only makes them for jets or something, not positive. they were a variable vane turbo, which was sweet, because they needed no wastegate. They also sppoled crazy fast. When I was going to UB, they had a snowmobile with one on it, it was crazy. I believe the brand name was aerocharger?
EDIT: http://www.aerocharger.com/
Originally Posted by mad-max98
oh youre talking about another miracle called vatn turbo which had 2 different turbine inlet sizes one is small for low rpm and the other is big for high rpm so you have fast spool up without having to deal with back pressure on the top end from having too small of an outlet
They still make the turbos, by the way. There are actually 3 companies in the world that make them (IIRC). I'm still debating, but this could very well be the turbo that helps power my car in the future...
Well now that I owe $1000 in taxes, I know for sure I will not be going boost anytime soon.
Can someone contact them about making an intercooled kit for our maximas?
Corporate Offices and Sales
Aerocharger Turbo Systems
8 Apollo Drive
Batavia, New York 14020
Tel: (585) 345-0055
Fax: (585) 344-5623
which one would we end up using: the 66000?
AEROCHARGER® Series 53000
• Small to medium displacement applications.
• Engine output range (for installations using a single Aerocharger):
Gasoline engines: 75 hp to 215 hp (66 kW to 160 kW)
Diesel engines: 51hp to 148 hp (45 kW to 110 kW)
• Four (4) turbine and nine (9) compressor trims available.
• Air Flow capacity: 136 cfm to 320 cfm (230 m3/h to 550 m3/hr).
• Charge Air Control: Diaphragm actuator, standard.
• Pressure ratio: 2.0, for continuous operation at maximum rated engine speed.
AEROCHARGER® Series 66000
• Medium to large displacement applications.
Gasoline engines: 120 hp to 350 hp ( 88 kW to 257 k/W)
Diesel engines: 80 hp to 235 hp (59 kW to 173 kW)
• Three (3) turbine and four (4) compressor trims available.
• Air Flow capacity: 214 cfm to 540 cfm (365 m3/h to 918 m3/h)
8 Apollo Drive
Tel: (585) 345-0055
Fax: (585) 344-5623
litch
123
Jan 4, 2024 07:01 PM
Keyno McMike
Sep 21, 2015 07:18 AM
I'll make my decision sometime later this year...
