Progress or Ingalls Camber Bolts
I am installing my Toser Coilovers and need to purchase a Camber Bolt Set.
Both Kits offer 2 Degree Camber but are there any benefits with one rather then the other?
Thanks.
JP
Thanks.
JP
Originally Posted by Big D
What benefits would there be? You need camber kits to adjust your camber when lowered 2" or more. Do you need it to do anything else? Where and how much were the coilovers?
http://maxmods.dyndns.org/index.php?MaximaCamberKits
I mean there is only 20.00 or so between the two, just wondering if either has an advantage over the other?
Originally Posted by slammed95
The camber plates won't move over time like the cheap cheap bolts. Another advantage is that they eliminate some of the sloppines of the rubber bushings.
now Progress. Oh, and if you combine plates & bolts you can go beyond neg 3deg camber.
How tough are these bolts? I think I remember reading on motorvate.ca that his Eibach bolts broke. I defiantly don't want that to happen but don't want to spend 200+ on plates..
Originally Posted by Triple8Sol
I've heard stories of these bolts snapping under hard cornering or something, so that pretty much scared me off. Can you imagine that at high speeds?
Could you slot the holes and still use the factory bolts? Maybe put another bolt or a spacer in there to keep it from sliding down the slot? You could weld something in there once you got the camber set correctly... this is interesting..
litch
123
Jan 4, 2024 07:01 PM
knight_yyz
Nov 1, 2015 01:34 PM
RealityCheck
Oct 2, 2015 06:34 PM
