External wastegate w/o the nipple on turbo?
Old Mar 9, 2004 | 03:01 PM
PoePoe2797's Avatar
How would I make an external wastegate work if there is no nipple on the turbo for the vaccuum line. Heres a pic of what I mean
BTW, the pic isn't mine, but the same turbo
The place fo the nipple is plugged. Is there anywhere else I can attach the vacuum line instead of on the turbo itself?
Also, does the wastegate need a vacuum to open or does it need pressure
Old Mar 9, 2004 | 03:08 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
you can weld on a bung/nipple somewhere on your intercooler piping before the TB...some even find a boost/vacuum source thats after the TB and use that(the wastegate gets "REAL" boost if you do it this way)
Old Mar 9, 2004 | 03:20 PM
PoePoe2797's Avatar
Ok, I have the perfect hole in the manifold for it....but i do need one thing cleared up:
So baiscally when pressure is in the vaccum line, the wastegate opens correct? Someone tried telling me the wastegate needs vaccum to open
Old Mar 9, 2004 | 03:44 PM
PoePoe2797's Avatar
Excellent, thats what I needed to know....it's not for my Maxima. Basically, I'm gunna remove the EGR, and use that opening in the intake manifold
Old Mar 10, 2004 | 07:28 AM
Stephen Max's Avatar
Does the feline have a nipple, maybe you can use it? But cats don't cooperate very well in such situations, I've found.
Old Mar 10, 2004 | 10:05 AM
SSR Engineering's Avatar
In all our years, we've seen plenty of turbo cars, ones by Greddy, IHI, Garrett, HKS, Blitz, and they all run the sticker to prove it. Now why is it I've never seen anyone run a KKK sticker?
Old Mar 10, 2004 | 06:29 PM
subs1000w's Avatar
i beileve Porsche uses KKK turbos for all there cars so there aperently pretty decent
Old Mar 10, 2004 | 06:32 PM
DA-MAX's Avatar
I think he's joking...you know KKK...Klu Klux Klan, don't think thats a sticker you want on the side of your car
Old Mar 10, 2004 | 06:34 PM
MardiGrasMax's Avatar
You could just drill into the housing near the discharge flange, tap it and screw in a fitting.
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
BkGreen97
Apr 2, 2016 05:47 AM
09maxshawn11
Sep 30, 2015 10:28 AM
uttadms31
Sep 30, 2015 05:24 AM
