See anything worng with this turbo?
Old Mar 11, 2004 | 10:08 AM
Bags's Avatar
VG Ridah's Biatch Hoe
My old turbo from Hal
Old Mar 11, 2004 | 10:13 AM
CiViC KiLLeR's Avatar
Wow,that looks like ****. Hope your new turbo works better.
Your turbo is bleeding!!!!!!!!!(JOKE)
Sid
Old Mar 11, 2004 | 10:15 AM
Stephen Max's Avatar
Dang! What happened to the turbine blades?
Old Mar 11, 2004 | 10:19 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Something contacted them, most likely engine bits from his blown motor.
Disect that sucker bags...I want to know how to take one apart and put it back together, so I can get my turbine housing Swain Tech coated.
Old Mar 11, 2004 | 10:43 AM
Bags's Avatar
I disagree. I do not think anything from my motor went down there. The car was not running long enough. And if you remember, my oil line was a STEEL line. it was TINY. No way anything got fed into from there.
And I was thinking about taking everything apart I could, since it is AFU. That way I would see how these things are built and understand them a little more.
Old Mar 11, 2004 | 10:59 AM
No bits of piston that might have traveled through the exhaust to the turbine?
If not, then how did it happen?
Old Mar 11, 2004 | 11:15 AM
Bags's Avatar
I am not saying yes or no 100%, but I don't think so. The only parts I ever saw or heard were in the oil pan.
I took the turbo off and no parts were heard in it or came out of it.
I am guessing I got it like this. I never took it apart until now. So I will never truly know.
I got a used POS turbo that was rebuilt 2 times by god knows who. It still leaked. So I am saying I received the turbo this way. Just the way I feel.
Old Mar 11, 2004 | 11:26 AM
=:O You think you got it like that? That's not used, that's junk.
You couldn't see the turbine blades with the housing on?
Old Mar 11, 2004 | 11:29 AM
Quicksilver's Avatar
OT n00bs FTMFCSL
Now there's an
I'll have to write that down in my journal of goodies...
Old Mar 11, 2004 | 12:11 PM
If you do not mind me asking what will Swain Tech coating do to the turbine housing.
Old Mar 11, 2004 | 12:25 PM
OT n00bs FTMFCSL
http://www.swaintech.com/
Call them and ask about their applications.
Old Mar 11, 2004 | 12:29 PM
OT n00bs FTMFCSL
Well, even a BB sized piece (or slightly smaller) of metal could have worked it's way through the line and gotten into the turbo housing. With the speeds your blades were spinning, it would do some serious damage to any type of hard material of anything. Believe me, I know first hand. Ever seen the compressor blades of a turbine after a bird ingestion? And that bird has nothing on it that's as hard as pieces of piston...
EDIT--> Still, I'll be glad to help with the total disassembly of both that and your old engine...
Old Mar 11, 2004 | 12:43 PM
JAY25's Avatar
Fck look at them turbine blades . Man I am very happy you got a new turbo. Well have to go dyno at Tylers place with this new one. I am sure you will get more HP/Tq out of this one.
Old Mar 11, 2004 | 12:44 PM
cnichols's Avatar
You got it like that? Are you retarded or something? Somebody linked me to this post because frankly it's hilarious. You really would have to be pretty smart not to notice that before it was put on since you had it off multiple times.
Old Mar 11, 2004 | 12:46 PM
Jeff92se's Avatar
I'm needing a caw
If I'm not mistaken, he didn't get a chance to look at the turbo when he got the kit. I assume he got the kit installed? If so, there's no real good way to see the turbo before hand. And to confirm if the blown motor did it or if it came that way. Nice 1st post btw.
Originally Posted by cnichols
You got it like that? Are you retarded or something? Somebody linked me to this post because frankly it's hilarious. You really would have to be pretty smart not to notice that before it was put since you had it off multiple times.
Old Mar 11, 2004 | 12:48 PM
cnichols's Avatar
Thanks, I thought it was a good first one as well.
I meant when he got it back after the rebuilds.
Also, am I correct in assuming that his motor blew up? And he doesn't think that could be related to his turbo's demise?
Old Mar 11, 2004 | 01:56 PM
Bags's Avatar
Well, thanks for your input. Wow, another nut swinger from KY.
And I am glad your here to help.
Can you see every inch of a turbine from the outside of the housing? I can't.. but then again, maybe your superman or you think hal is or you are hal.
Either way, I don't give a flying you know what.
My turbo was doomed from day 1. No matter if my motor put it out of it's misery or not.
If you'd like a flame war, look else where.
Old Mar 11, 2004 | 02:34 PM
OT n00bs FTMFCSL
Where the hell did this fool come from? Crawl back under your rock FNG...
Old Mar 11, 2004 | 02:53 PM
Bags's Avatar
It may very well have justin.
I have been through so much BS over this POS turbo, pipes, oil return, oil feed, etc.. that I feel ok in saying that I received it AFU.
But, I am slowly improving my setup, so it will work 100% and be right.
Old Mar 11, 2004 | 03:15 PM
IceY2K1's Avatar
Nut swinger? LOL!
Oh thanks Bags...needed that after all the jack offs in my 5th gen forum right now.
Anyways, my first *GUESS* was debris of some sort, but maybe the blades overheated from being lean too long and desintigrated(sp?). I don't know, just poking in the dark here.
I *DEFINITELY* think we should persue what happened though, so that we can diagnosis what went wrong and prevent it from happening to you or others AGAIN. TC failure analysis is a bit of science we can all do and learn from it and improve to make the setups better in the future.
Old Mar 11, 2004 | 03:31 PM
JAY25's Avatar
yeah crawl back under the rock you FNG Nut swinger
Old Mar 11, 2004 | 03:41 PM
IceY2K1's Avatar
Hey Bags,
Try and move it back/forth and side/side. What kind of shaft play does it have?
Old Mar 11, 2004 | 03:58 PM
IceY2K1's Avatar
Also, once you clean off all the oil, post some more pics.
You can also SELL that to someone looking to avoid a core charge SUPPOSEDLY, so don't toss it.
I'd make it a trophy of sorts though.
Old Mar 11, 2004 | 05:27 PM
Bags's Avatar
Hey Bags,
The spacer/bearing between the center section and the turbine wheel has at least 1/8 of an inch gap in it.
I'm at work now, but I would like to break it down shotgun style.
I will clean it up.
I dug my finger in the turbine housing and it feels smooth, no gouges or anything. I will mess with it more in a day or 2.
And I do try and give people a good laugh every now and again.
I may keep this, not as a trophy, more of a future experiment.
Old Mar 11, 2004 | 08:23 PM
Bags's Avatar
Now there's an
You prefer that over ceramic coating?
I looked at it, it "appears" to be about the same thing
Old Mar 11, 2004 | 11:57 PM
DAVE Sz's Avatar
Hooooooonda.....
Maybe it was the bad turbo that made your motor blow in the first place?
Old Mar 12, 2004 | 08:08 AM
deezo's Avatar
Ice thinks a motor blew its guts before you were given that turbo to put in your car.
Old Mar 12, 2004 | 09:47 AM
Bags's Avatar
Thanks deez. I see the "he" now. I thought it ment me...... ICY may be 100% correct. No telling with that POS hal.
Old Mar 12, 2004 | 10:02 AM
vortechpower's Avatar
Man that **** is looking busted. Leaking oil and all are you sure thats not out of a Mitsubishi??? just kidding that really sux
Old Mar 12, 2004 | 02:46 PM
Bags's Avatar
And I am replying to this a 2nd time...
It took your fisrt post to get my brain housing group working and I came up with a few situations.
And then vortechpower replied and it was odd that he said DSM.
The place that did my POS kit had 2 dsm's, both were shop cars. 1 early 90's talon, the other a newer body style eclipse. The eclipse had recently blown the motor and the talon was running.
I am now thinking either
A) the shop owner who installed my AFU kit, shafted me with his OLD turbo out of his eclipse and Hal had no idea..... or
B) Hal and his buddy F'd me with the used turbo from the eclipse. And they kept my money and bought vaseline so they could be butt buddies.
Interesting. If any of you Hal lackeys wanna toss this thread his way, I'd be interested in what he has to say. Well, I would not believe him if he told me he had no idea.
Funny how things fit together after you look at all the parts.
Old Mar 12, 2004 | 07:13 PM
OT n00bs FTMFCSL
Hindsight always being 20/20 (which can be good or bad)...
Well either way, Hal is still the responsible party since he supplied both the parts and the place of install.
Old Mar 15, 2004 | 04:19 PM
Kenneth's Avatar
OG :)
Baggs, it seems like you've replaced every piece of Hal's turbo kit. Personally I'd be steammed considering how much a replacement turbo cost
Old Mar 15, 2004 | 04:22 PM
Bags's Avatar
Steamed was last year. I am way beyond steamed. But that anger gets me no where. So I sit on it and hope one day I can use it.
And the fact that my car looks better and is running better makes, it makes me feel better
Old Mar 15, 2004 | 07:54 PM
SSR Engineering's Avatar
How did your motor blow?
Old Mar 15, 2004 | 08:23 PM
Larrio's Avatar
The Definitive AE Master
bags, u didn't run that turbo for a whole year like that did u? Thats insane.
Old Mar 15, 2004 | 09:26 PM
Bags's Avatar
Great question.
I'd say my pushing the boost without proper fuel.
Larrio- again, I THINK it was like that from the day I got it. Not 100% either way. But, the turbo has been leaking from those 2 bottom bolts since the 1st day it was installed on my car
Goldenglory- 1 motor replaced, 1 transmisson swap, 1 Turbo replaced. I don't make that much money. I plan well and work LOTS of OT to pay for what I got. And american express loves me..lol
on B.. Lead the way
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
BkGreen97
Apr 2, 2016 05:47 AM
09maxshawn11
Sep 30, 2015 10:28 AM
Keyno McMike
Sep 21, 2015 07:18 AM
