235/50/17 on 04 Altima Rims
Old Mar 16, 2004 | 07:39 PM
s0ber's Avatar
Would it fit?? On my 4th gen.... I know the rims fit, im talking about the tires...
17x7 45mm offset
235/50/17's
Old Mar 16, 2004 | 09:06 PM
schernov's Avatar
17/7 rim can safely hold 225 size tire. anything over that is not recommended, but may people run it with mixed results.......some get bubles, some don't.
Old Mar 17, 2004 | 03:51 AM
s0ber's Avatar
The rims already have the tires on it, I dunno why there are 235's on it... Just temporary tires anyways.
Old Mar 18, 2004 | 05:49 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
235/50 is in spec for a 7" wheel. check tirerack for confirmation but 235/50 fit fine on my 5th gen with maxspeed springs. i am not sure what springs you are on but most 4th gens that i have seen have larger wheel gap stock than 5th gens so you should be fine.
Old Mar 18, 2004 | 06:53 PM
s0ber's Avatar
Hmm, Im dropped on H&Rs... I just found out the wheel not 17x7, there G35 rims... so rear 17x8 and front 17x7.5
The rear tires are 235/50/17 and the front I think are 225/45/17.. I put the rear in the front and I had about an inch of clearance, no wheel gap there..
In the rear they are fine, so I think im good to go since the fronts have smaller tires.
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
trsandrew
Apr 8, 2016 06:45 PM
doctorpullit
Dec 12, 2015 09:39 AM
trsandrew
Oct 25, 2015 02:47 PM
BobTX10
Oct 7, 2015 08:43 AM
