235s on stock 17s.
Old Mar 22, 2004 | 11:29 AM
slvr2KSE5's Avatar
235s on stock 17s.
yeah i know you "cant" do this but......i did anyways.
ill post a couple pics when it stops raining but it doesnt look bad at all. best part was i replaced the 46k mile blowtenzas (still had tread...on 2 of the tires at least) with kumho ecsta MX 235/45/17. traction is much better and handling improved too.
Old Mar 22, 2004 | 12:17 PM
03maximan's Avatar
I've heard that the 235's wear fast in the middle of the tire due to sqeezing a wider tire into stock rim
(meant for 225 tire). Just don't run with a lot of PSI.
Old Mar 22, 2004 | 01:21 PM
Dany's Avatar
I just received HTR+ tires from tirerack in 235/45 17 size, going to install them on my stock
17" as well.
Old Mar 22, 2004 | 01:59 PM
Jimmy Gardner's Avatar
I am running 235/45/17 Nankang NS-2 on my stock rims with no complaints at all, if anything, this is a better tire than factory, they handle so much better and tread water better, but anything id better than Craptenza's. But I have experienced no problems with the 235's, it throws the speedo off about 5mph and it makes the MPG guage read a little less than stock, but that don't bother me none.
Old Mar 22, 2004 | 02:12 PM
E55AMG2's Avatar
Wat
I run 235/50/17 on my 2003. But the tire specs say that it can be mounted on a 7" rim. BTW, the tire is a Michelin Pilot Sport A/S
Old Mar 22, 2004 | 04:23 PM
trey
So whats the advantage of going with the 235's?
Old Mar 24, 2004 | 05:32 AM
Ammi's Avatar
350 Detroit Muscle
just little more rubber meeting the ground
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
jaydot901
Sep 29, 2015 01:18 PM
