Better low end??
Better low end??
I just installed my cold air and it helped my mid range a ton but I want a quicker jump off the line. Is there any easy things I can do or what have ya'll done to improve your low end
Originally Posted by billy_corgan
What you need to do for the low end is exactly opposite of what you did.....take off the cold air intake and put the stock airbox back on. It is pretty much the general consensus that Cold air intake helps mid to high range horsepower and response. However, pretty much to date, nothing has shown to beat the throttle response and low end power of the stock box/setup.
A y-pipe would help your power. It does help under 3500rpm...it adds a lot of torque which is what you use off the line. It is a great mod, and takes nowhere near 2 hours to install. It is much easier than that, so go get one and do it.
Originally Posted by Brudaddy
What is that? A black man's Pen is? ha ha ha. That was a good one.
In my experience with my mods, I have low end power with the intakes and exahust bolt ons but high end power more than makes up for it. If you want some that will get u off the line quicker (like at the track or something) I would say put a 50 shot on it. just my $0.02
maxima98vspec, if you will use some rust penetrating spray on it tonight and tap on the bolts and then leave it for the night. Then, tomorrow, do the same thing. Then Saturday, it should be loose enough that you can get the bolts off without having to drill them. It would be worth the try. I did this and had no problems.
aite guys...please read his question again
...but I want a quicker jump off the line...
CAI usually has horrible throttle response, therefore kills a quick jump off the line. don't depend everything on modification, there's couple other things you can do to help you get a better jump off the line:
1. tighten your throttle cable, it helps your foot and gas pedal react a lot faster
2. pump up your all 4 of your tires +4 psi higher than whatever you have, now try again. although you lost some tracktion, but your tires are making less contact with the road, therefore better start.
3. you may wanna swap your CAI to short ram like above orgers said to improve throttle response.
4. weight deduction, clean up your car, throw craps outta your car.
then...
5. spend $$$$ on other performance mods
then...
Originally Posted by Jeff92se
Ah CAI has WORSE lowend? Since when? It's the HAI intakes that soften the lowend a bit.
The CAI should help the low end by putting the intake's resonance frequency lower in the rpm band.
That's exactly what I was thinking....
Yeah I thought the damn CAI was better for lowend and HAI better for mid range or high end or something... Whats with the mixed opionions, thats what I always read here on teh org... Someone wanna put in there 2 dollars to correct this? :P
My $0.02 wasn't enough for you?
go read a lot of other posts about all the different intakes. Those that have either short ram (just cone) with stock resonator, or the stock setup with the snorkel and all have the best throttle response. I am not saying they have the best top end, but better TR. Also, when you modify, sound does not equal better throttle response or more hp necessarily, although it might "seem" faster.
You know this directly contradicts all long / short tube theory right?
all I know, Jeff, is that more people than not have told me that the stock airbox has a little better low end torque and throttle response. I am not claiming to back any of this up with my own experiences as I still have only the stock airbox.
Mar 12, 2020 12:06 AM
