Nismo FPR
Old Mar 24, 2004 | 08:24 PM
slimer's Avatar
A couple of Blaxxx's? Lawls.
Nismo FPR
does anyone know if the Nismo FPR will fit like stock in the stock location?
these can be found on ebay for around $120
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2468896740
im trying to get a stock sr20 fpr so i can test fit it on our vq
Old Mar 27, 2004 | 12:28 PM
zMax1996's Avatar
I bought a NISMO FPR for my 96 SC Max as a part of a WALBRO Fuel Pump upgrade. The Courtesy Nisssan in Texas NISMO FPR did not fit. I returned the NISMO FPR and am running with the original stock
FPR at 41 PSI IDEL with no problems.
Details are somewhere in archives posted back in January of this year.
Old Mar 27, 2004 | 12:54 PM
jdmmax's Avatar
there is a nismo universal fpr you can buy.
there is a fuel rail fitting you can buy as well.
Old Mar 30, 2004 | 11:28 AM
slimer's Avatar
the stock sr20det fuel pressure regulator is the exact same as the oem maxima one. It fit in the stock location.
the nismo works on the sr20det's, why wouldnt it work on ours?
the only reason why i would think that i might not work is because of that tail on the lower end.
when i get my hand on one (i know a guy that has one), ill do a test fit with that
Old Mar 30, 2004 | 06:26 PM
Maximus101's Avatar
www.OBXracingsports.com makes a very high quality regulator that comes with the fuel rail adapter & mounting brackets. You should be able to get one for about $90.00 bucks. Tunable from 20psi to what ever your fuel pump will put out. I think it will handle up to 1000hp & it's pretty looking?
Old Mar 30, 2004 | 08:16 PM
slimer's Avatar
yeah, i found those today, i have the aem.
Old Mar 30, 2004 | 08:56 PM
BlackBIRDVQ's Avatar
drag racing is for wussies
not to knock anything down, but would ya trust an OBX part that if failed could damage the motor ?? Only diff between the NISMO FPR is the return line outlet tube is longer than the stock. It will bolt right up to the rail thou. Slimer I will take off mine and see if the SR one is same as a VQ.
Old Mar 30, 2004 | 09:33 PM
slimer's Avatar
hey, ill just bring my stock one when im @ McGrath next time.
btw, i should get the safc2 by this weekend
Mar 12, 2020 12:06 AM
05RLS2
Apr 14, 2016 11:49 AM
msellas
Sep 23, 2015 09:16 PM
ToTheMax305
Sep 23, 2015 09:11 PM
Team STILLEN
Aug 10, 2015 04:29 PM
