Can you Clear it up???
Old Mar 31, 2004 | 11:01 AM
crewchief264's Avatar
i am currently running an intank 255lph holley pump(not high psi), with factory injectors, and no adjustable fpr. If Iwere to say just install the 370's would the compensate itself for fuel, or would it run rich without a baseline fuel psi change, (Iam now running about 35-37psi at idle, with no problems, and its not rich). Shouldn't the computer notice the added fuel flow of the new injectors and just drop like the injector open time or something?
Old Mar 31, 2004 | 12:02 PM
BigDogJonx's Avatar
You put in the 370s and it will still be at 35-37psi idle. So basically the may not even crank cause it will be flooded. Sometimes it may start if you get lucky, but the idle will run like crap.
Only way you will get around not using an FPR, is putting the Z32 maf in. Otherwise need to lower the base Idle to at least 24psi.
Dixit
Old Mar 31, 2004 | 03:03 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
If you get the injectors, you'll need an adjustable FPR to drop down the base fuel pressure to 26-27psi.
If you get the injectors AND a Z32 MAF, you'll need an AFC to add more fuel to prevent detonation at stock 34psi fuel pressure...check for StephenMax post on S-AFC settings.
Old Apr 1, 2004 | 10:57 AM
where to get em
where is a good place to get the injectors? and are they basically just stock 300zx tt injectors? also where to get adjustable fpr? And which one? saw one on curtesy nissan?????
Old Apr 1, 2004 | 11:01 AM
IceY2K1's Avatar
PLEASE read some of the threads IN THIS FORUM.
Scroll down and go back several pages and you'll find GREAT information. If you still have questions, post them.
Apr 16, 2020 05:15 AM
doctorpullit
Apr 23, 2017 05:35 AM
uttadms31
Sep 30, 2015 05:24 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
