My struts are beat, time to lower?!?! *PICS*
Well this morning i was outside working on my car gettin ready to clean her up, and i noticed when i was wiping my wheels that my struts have cracks in the boots. I would assume that this means i need new struts and springs, am i right? I am now thinking maybe i will just lower my car, i was thinking about getin H&R springs and tokico illuminas struts. I hear they are a great combo and will give me a ride that has the feel of the stock suspension minus the horible wheel gap and crummy turning. Is this a good idea, and how much will this cost me.
Here are some pics of my struts
Driver Side:
Passenger Side:
-Tom
Driver Side:
Passenger Side:
-Tom
well if you are just looking for an excuse to lower your car, then yeah its time. But no as long as your struts are not leaking you are fine. Those little cracks on the boots don't mean nothing. My boots are in like 4 pieces
yea, you still have boots on your struts. as long as i have owned mine none of them had boots. there is just a little peice on either end where they used to be in some long forgotten time.
good exuce to drop the car though
My boots are all ripped up the same way, anyway, kinda the same situation here. I went to get my car inspected and failed because of a leaky rear driver side strut, so I said **** it and bought Tokico Illumina kit from custom maxima.
I don't think a bad strut will always leak. When a strut no longer does its job of damping the suspension, it's time to replace it. If it's shot, you'll notice the car doesn't settle down quickly after hitting a bump. The car will continue to "bounce" on the springs after hitting bumps. Also, the springs don't really wear out. As long as they're not cracked, they're OK. However, if you want to lower it, go for it. I just did, and I love it! Also consider getting new mounts/bearing for the front, and of course, new boots all the way around.
Good luck.
Good luck.
I don't think that you have bad struts if your boots are shot but if i were in your situation go for an upgrade or new/used struts.
I have a set of OEM struts for sale if you need them. This is for your own good.
your struts are in perfect condition. you dustboots are only torn by a tiny bit. u should see mine, all stripped away, yet my shocks are still running strong.
you can run shocks without dustboots, but it's recommended to pair up shocks with dustboot to let the shock last longer. my friend with koni yellow did not have any dustboots for 2 years, his shocks are in perfect condition.
if you want, you can replace the dustboots (which IMO is not necessary at all).
95Maxi
35
Sep 2, 2015 10:37 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
Greenmaxspeed
Aug 8, 2015 12:39 PM
laparka66
Aug 6, 2015 09:36 AM
