Y dont more people use a 2.87 pulley?
Old Apr 7, 2004 | 11:41 AM
luckee2bhere's Avatar
Most of you SC guys are running the 3.125 pulley right??? that boosts at what 10-11 psi?
why dont more people use the 2.87...I mean...people have showed the VQ can handle loads of power so I dont see the reason being that people are afraid of blowing motors...whats the reason?
is 10-11psi enough for you guys?
whats the deal?
also whats the 2.87 max boost psi?
Old Apr 7, 2004 | 11:59 AM
matty's Avatar
scared...I will be using the 3.125....Im scared enough running that pulley
-matt
Old Apr 7, 2004 | 12:10 PM
KLoWnPR109's Avatar
I think it has more to do with overspinning the blower rather than being afraid of the power
Old Apr 7, 2004 | 12:35 PM
ejj's Avatar
ejj
Correct. A 2.87 will overspin the blower. Shouldn't be a major problem though as long as you don't hold it at the redline for a long time (top speed run or something).
I plan on getting a 2.87 once I get my current fuel issue worked out.
Old Apr 7, 2004 | 03:13 PM
If you overspin the blower does that mean you totally destroy it??? how much is it to replace? or fix?
Hey ejj,
why engine number 2???
Old Apr 7, 2004 | 03:16 PM
MaximaRider's Avatar
Im pushing my daily driver enough, why stress it anymore? Rather have a different car with a different drivetrain, whats the point of having more than 300hp in a fwd car? Basically its fast enough for what it is.
Old Apr 7, 2004 | 03:18 PM
If I remember correctly one of the screws on his MEVI fell into his engine and it went boom?
Old Apr 7, 2004 | 03:24 PM
BigDogJonx's Avatar
The issue is not more over spinning the blower, more of the issue of detonating. You need to have a J&S to do the timing retard. Otherwise at 13-14psi you detonating (inaudible) which is damaging it already.
Dixit
Old Apr 7, 2004 | 03:39 PM
whats J&S?
Old Apr 7, 2004 | 03:42 PM
BigDogJonx's Avatar
http://www.jandssafeguard.com/safeguard.html Boost related timing retard unit with knock detection retard.
Dixit
Old Apr 7, 2004 | 03:43 PM
ejj's Avatar
ejj
Correct. Nothing to do with the SC.
I'm not going to worry about the engine and just up the boost. I am however going to use race gas when I'm at the track and get a wideband before that.
I don't see the point in investing hundreds if not thousands on protecting an engine that only cost me $500. If I break it, I'll just replace it again.
Old Apr 7, 2004 | 03:46 PM
Dixit
how much is that?
and did Mardigrasmax have that?
Old Apr 7, 2004 | 03:47 PM
BigDogJonx's Avatar
Mardisgrasmax did have one. It costs about 550 i believe without the gauge/monitor, and 700 I believe with.
Dixit
Old Apr 7, 2004 | 03:49 PM
what about psi??? going to see max boost at 15psi with 2.87?
Old Apr 7, 2004 | 04:26 PM
Bags's Avatar
VG Ridah's Biatch Hoe
At some point the ~$700 j&s would pay for itself
I understand what your saying, but I think most of us would rather have safe reliable power.
I am not one to talk, I blew my motor due to a lean condition
Old Apr 7, 2004 | 04:58 PM
ejj's Avatar
ejj
If you go through engine after engine, then yes. However, I'm going to see just what a stock engine with a stock computer (no J&S) can do. I don't boost much on the street. I think with race gas at the track and good tuning, you may be fine without a J&S.
Old Apr 7, 2004 | 05:57 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Hey, for $539, you can tune your AFR and TIMING with a Split Second FTC1...if you have a laptop.
J&S Safeguard is better, but you still need an AFC, so add another $200-$300 on top of $600-$700.
Old Apr 7, 2004 | 06:56 PM
matty's Avatar
is J&S needed with a 3.125 pulley ??
matt
Old Apr 7, 2004 | 07:01 PM
IceY2K1's Avatar
You don't need race gas, just get Aquamist and run a 50/50 mix of water/alcohol.
Old Apr 7, 2004 | 07:19 PM
ejj's Avatar
ejj
Nah. Aquamist is expensive, and robs boost/power. Yes, its a good idea, but seems over the top.
If I were to consider that option, I'd go for a small shot of nitrous (wet kit) first.
ilumo's Avatar
how much is that?
Or just get an intercooler of some sort... an AWIC or a FMIC. That would help you lots when you are creating that much heat from boost. Then you can avoid getting the J+S until later on. The AFCs are definately reccomended to richen up the upper RPMs if you need.
<shameless plug> I have my ICed S/C kit for sale! </shameless plug>
Old Apr 7, 2004 | 07:59 PM
IceY2K1's Avatar
Robs boost/power?
Nah, you're mistaken. Kev gained with his.
$420 and free refills is cheap IMO.
Old Apr 8, 2004 | 04:47 AM
ejj's Avatar
ejj
Robs boost/power?
Are you a sales rep for them or something?
I'm not considering Aquamist an option. Just not a road I'm interested in going down.
Old Apr 8, 2004 | 08:42 AM
iansw's Avatar
No - more like 12PSI. That's what I hit regularly on my 2.87".
MardisGrasMax was running a 2.6" Pulley when he hit 13-14PSI, not a 2.87"
IanS
Old Apr 8, 2004 | 08:48 AM
ejj's Avatar
ejj
IanS
Matt had a V1. Do you have a V1 or V2?
Old Apr 8, 2004 | 09:10 AM
iansw's Avatar
V2 with a V1 Bracket.
Old Apr 8, 2004 | 10:22 AM
Prodeje79's Avatar
What about overspinning with a 7200RPM limiter?
I am too nervous to run a 2.87 with my 7200RPM limit, 100k engine, and the 220 PSI compression test.
Thanks, good game.
IanS: what PSI do you see at 7200RPM?
What were your compression test results?
Please convince me to run the 2.87 on my only car I own.
Old Apr 8, 2004 | 10:57 AM
iansw's Avatar
I hit my 7200 RPM limit all the time with only 1-step colder plugs even.
The compressor and engine both seem to be running perfectly.
IanS
litch
123
Jan 4, 2024 07:01 PM
mkaresh
Mar 12, 2018 06:48 PM
BobTX10
Oct 7, 2015 08:43 AM
