kosei rt valve stem prob. bike-tire size?
Old Apr 10, 2004 | 03:43 PM
bobjohnson's Avatar
Blazin......
Hello all, Ive had these Kosei RT 17x7.5 wheels for a bit.
I went to a few different shops but my valve stem hole is so small its ridiculious. There the deep version thing and the valve is on the lip so it cant be drilled.
(see homepage)
Do they make special 2piece valve stems i read somewhere?
Can someone help me at all on this. much appreciated.
mwest.
Old Apr 10, 2004 | 09:14 PM
Blk2kMAXSE's Avatar
lol.... i had the same prob about 2 yrs. ago when i had some kosei wheels. those valve stems are hard to get. i went to big ten tires and looked through their catalog (i think they're all chrome and it bolts on in the back). the valve stems had to be specially ordered. tried everywhere in town. they were a real b!tch to get. good luck.
Lam
Old Apr 10, 2004 | 10:59 PM
kingrukus's Avatar
no more maxima...
The Kosei's I had bought had come with skinny metal valve stems.
Old Apr 11, 2004 | 03:58 PM
grody's Avatar
Do they look like this?
If so, they're called Presta valves, also known as French valves. They hold air better than the Schraeder valves found on most wheels. They are commonly found on bicycle tubes, and you can get just the valve if you go to a bike shop and ask for a set of presta valve stems for tubeless mountain bike wheels.
Old Apr 11, 2004 | 07:37 PM
kingrukus's Avatar
no more maxima...
This is exactly what came with my Kosei Double Racer RT wheels:
Old Apr 11, 2004 | 08:55 PM
Blk2kMAXSE's Avatar
thats them, they are a b!tch to get. i had to special order mine when the black rubber piece wore down.
Lam
Old Apr 11, 2004 | 09:01 PM
Mick Max's Avatar
Wild at Hurt
This is a great idea, but get the adapters for them to be filled by a shreader type air hose. They screw on like a cap.
These really do hold air better. Used to olympic style bike race and the presta valve will hold 120-130 lbs just fine.
Old Apr 11, 2004 | 09:23 PM
grody's Avatar
They'll hold over 200psi with no problems. The adapters can be found at a bike shop too, about a buck. Make sure you take the adapter off and close the valve back up after inflating.
Old Apr 11, 2004 | 10:29 PM
bobjohnson's Avatar
Blazin......
Huh all great ideas. thanks alot for the help.
I did however find only 2 original valve stems, seems i was shorted the other 2 though..oh well.
thanks again
Miket2006
Mar 1, 2021 03:55 AM
TKHanson
Nov 24, 2018 01:39 AM
knight_yyz
Nov 1, 2015 01:34 PM
tseng1023
Oct 15, 2015 08:30 AM
