line output tuning??
I have a question on the line output convertor I installed and tuning it? when I give the car gas say like 2000 rpm the speakers shut off and then once the motor levels out they come back on. Its like the line convertor is a circuit breaker??? keeping something out, is this normal??
Also those gains on the output convertor? Is that how I adjust this problem??
i am running an pioneer dvh-p7000 with monitor and stock bose speakers.
its just the sound that shuts off? or does the unit shut off also? i would try to adjust the gains on the line otput controller, they shouldnt be up too high.
yup
the sound just shuts off nothing else. video still plays etc .... it also does it if I turn the headlights on or when I put up a window???? or blinker, but and it hass been when the car was running.
Sounds like you either have the LOC powered with a relay and it is wired up incorrectly, and shutting off any time an accessory is on. Or your amp has poor wiring and everytime there is a slight voltage drop it shuts down. I would triple check the power wireing and fuseing.
I fixed it!!!!
Heres the deal. the gain adjustment box I put in to be able to use the factory speakers-BOSE- with my dvh-p7000 needed to have the ability to adjust the gain for each speaker. Well the box had wiring for each peaker and it also had wiring for the power and everything. So.... I just didn't run the power through the box and just ran the speaker wires through it,, now it doesnt shut off and i can still adjust the gain!!!
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
