LEDS Hamy has on my Max...PICS
I bought the 9 led bulbs that Hamy has on his headlight markers, and I finally put them on tonight.....
....This is the brightest bulb I have ever seen and it looks great ! Thanks for the tip Hamy !
I took 2 pics , one with , and one without the flash...these came from www.autolumination.com
....This is the brightest bulb I have ever seen and it looks great ! Thanks for the tip Hamy ! I took 2 pics , one with , and one without the flash...these came from www.autolumination.com
Damn those are bright. Now all you need is some DDEs in them thangs. I might be looking for some 9 led bulbs for my rear side markers. The $3 bulbs from wal-mart aren't cutting it, but have done just as good as some of the $18 bulbs I've had back there.
Will the 921 fit in the clear corners????
Originally Posted by nissan5788
921 9 LED bulbs will work if there's enough physical room in the opening to stick it in.
Btw. the same person who runs autolumination sells on Ebay..there, you can buy the bulbs $1-2 cheaper.
Look at the 921 bulbs....in case some of you dont know , 921/194 are the same bulbs........Now I need to try them tomorrow, to see if they fit my clear markers.....then I might really have found some bright LEDS for them...
looking good kloogy..btw did u buy the blue leds or white leds??
and the 9 LED bulbs would cause your blinker to blink fast if the bulbs were drawing less voltage than normal marker bulbs..which i don't think they do??
When did you order yours???
I ordered mine tonight ... Want to know how long it'll take
1.
Item Name: 24 Matrix LED
Item Options: Color: Super White
Type: 1157
Quantity: 2
Total: $29.98 USD
2.
Item Name: 9 LED
Color: Super White
Item Number: 921
Quantity: 2
Total: $13.98 USD
3.
Item Name: 6 LED
Color: Super White
Item Number: 194
Quantity: 4
Total: $19.96 USD
4.
Item Name: Shipping Insurance
Item Options: $100:
$1.30:
Item Number: Up to $100
Quantity: 1
Total: $1.30 USD
Cart Subtotal: $65.22 USD
Shipping: $5.00 USD
Sales Tax: $0.00 USD
Cart Total: $70.22 USD
1.
Type: 1157
Quantity: 2
Total: $29.98 USD
2.
Item Name: 9 LED
Color: Super White
Item Number: 921
Quantity: 2
Total: $13.98 USD
3.
Item Name: 6 LED
Color: Super White
Item Number: 194
Quantity: 4
Total: $19.96 USD
4.
Item Options: $100:
$1.30:
Quantity: 1
Total: $1.30 USD
Shipping: $5.00 USD
[QUOTE=kloogy]I bought the 9 led bulbs that Hamy has on his headlight markers, and I finally put them on tonight.....
Did you have to buy the LED Load Equalizer to make the LEDs work? If so, which load resistance did you buy - 6 or 3 ohm? Thanks in advance.
you only have to buy load equilizers if your putting leds in ur blinkers or brake lights
kloogy put them in his sidemarker light inside his headlights....they never blink they jsut stay on....so you dont need a load equilizer
-J
-J
Like I said, order the 9 led 921 bulb. It matches perfectly with the 194 socket. I figured I'd give it a try, since Ive used 921 bulbs , before on 194 sockets. No I did not need a load equalizer.......
I have the 6 LED ones. Autolumination is a great company. I got a bad bulb and they replaced it for me immediately.
Oh and those 9 LED ones are crazy bright! Didn't know that would work in the 194 application.
Originally Posted by Hamy
I'm glad you like them Kloogy! I had no idea that they made 9 bulb LEDs that would fit the 194 socket. Here is the picture of my 6 bulb LEDs.
They are the super white I got them too but mine don't match so I have to return them. I got one that looks blue/white and the other one is purple/white color. I told them that I wanted them to look purplish. And they are going to fix my missed matched lights. Execllent service.
I ordered on the 27th and got them 4 days later on the 1st of May
Any one know what LED bulbs to get for map and dome lights ? ? ?
I was also thinking about getting the blue or Violet for my brake lights to get the blue red look like the old cars with the blue lens in them, just looks different.
What do you Guys/Girls think? ? ?
Would it work ? ? ?
Would it work ? ? ?
Originally Posted by maximilion
what kind of bulb do the blinkers use? And if I wanna use LEDs, what resistor will I need?
Kloogs, sorry for hijacking your thread.
Type: 1157
Quantity: 2
Total: $29.98 USD
Rear 1156
Would it work ? ? ?
Would it work ? ? ?
Wow hamy I like ur max, I'd put hyperwhites on those clear corners, it would match your headlights more and it would help it stand out more in the night..Just a suggestion, anyway out of all the maxima's on here I Like your's the best..
