Got a NOS kit and got questions.
Old May 3, 2004 | 02:14 PM
C3nthusiast's Avatar
I bought a NOS dry kit. It have the following:
10 lb bottle
bottle warmer
arming relay
hoses
50,75,100, etc. jets
Auto Meter pressure gauge
WOT switch
My car is a 99 w/ automatic transmission and traction control. From what I've read I suppose I need a purge valve and window switch??? Anything else?
Old May 3, 2004 | 02:19 PM
DaThrillr's Avatar
nice GL with the kit
well u dont need either of the 2 at the moment u really dont need the bottle warmer but is good to have
did u buy the kit brand new or used?
Old May 3, 2004 | 02:42 PM
SonicDust187's Avatar
Can I get that Sub Machine gun with silencer? oh turn the TC off when spraying. Or you will blow your motor.
Old May 3, 2004 | 03:03 PM
USED. I guess the bottle warmer would be for the winter?
I'm assuming the WOT will activate the NOS. At what point does it stop spraying? My friend used a button to spray. What is best? Keep in mind I don't race at the track. I just want this for fun and maybe surprise a Mustang or two.
Where on my Injen should I drill for the nozzle?
Sorry for the newbies ???'s. I've read a lot and I'm still quite lost.
Old May 4, 2004 | 09:41 AM
DaThrillr's Avatar
ok about the newbie questions.. please refer to the FAQs and pictures of other peoples set-ups ... i have the NOS 05124 instructions if u need it. if u install the kit according to the instructions then u will understand everything about using the kit...also is a good idea to cross reference the parts u have(bought) with the parts necessary for install
the best place to drill the hole is anywhere after the MAFS and the vacuum lines, the closer to TB the better
Old May 7, 2004 | 01:28 AM
desertmaxima's Avatar
No bottle warmer is to keep the pressure up in your bottle cause you want it to be around 900-950 psi 1000 at the most I believe. And sometimes sitting in your truck or at night or something it gets down to 750 and its not a potent shot. Purge is a good idea if you want to shell out the dough. Only cost about 100 bucks or so. It is really good to get the air out if the line and have just nitrous spraying just dont be all gay and curious (fast and furious) and purge around everyone to show off, then your wasting nitrous and that aint cool. WIndow switch lets you program your system to spray at a certain RPM that you program. Good idea I guess if you have a stick, but you got auto tragic like me so just try to find a WOT switch that comes with the kit and hook that up as shown in the directions. Belive me youll have tons of fun, oh and before you put that 100 shot jet in make sure you upgrade fuel system, ie fuel pump or kaboom you will go good luck and ma the force be with ya
Apr 16, 2020 05:15 AM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
Pied
Sep 26, 2015 03:29 PM
