Door/Driver's Window/Sunroof Problem
I recently bought a system for my car and put in different door speakers and everything sounds great but now when i close my door the sunroof opens and so does my driver's side window. Has anyone every had this happen to them or does anyone know what has happened or how to fix it? This problem is really new to me. the car is an 89 gxe if that matters or not! I thought it might be somthing with the keyless entry although the keyless entry hasnt worked on that side for 3 years! Help is much needed!
Drew
Drew
wait for Craig B to read this.
But did you have this prof. done? if so send it back and tell them the prob and have them fix it for FREE or if you did it your self then check your wiring and see WHAT WIRES YOU SPLICED TOGETHER.
yea i did the whole thing myself! I wouldnt know what to look for even back there i didnt do any splicing or messaround with any wiring back there all i ever did was take out the old speaker and put in the new one. The whole thing worked fine for about 3 days then it all went to Hell i have no idea what wrong or even what to look for! Craig's help would be much appreiciated
Originally Posted by daggett92se
How do i get ahold of Craig
http://www.geocities.com/craigbrace
I really think it has to be something to do with your keyless entry. This is nothing else in the car that would make all those things happen like that - especially with the car off (I'm assuming it's off when you close the door).
Go back in the door and check out the keypad and also check around wher you put the speakers and make sure you didn't pinch, cut or expose any other wiring.
If you cant figure it out, you could unplug the main keyless unit (under the dash, to the right of the glove box) and I bet this would stop, but you wouldn't be able to use the keypad anymore.
litch
123
Jan 4, 2024 07:01 PM
jmlee44
Oct 2, 2022 02:13 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
