transmission meltdown. Cause?
Old May 20, 2004 | 06:04 PM
grendel's Avatar
My automatic transmission has problems.
The
Sun gear lost all its teeth and all three planetary gears are flat on one side. This is the second one. Any idea what make this happen?
Old May 21, 2004 | 05:38 AM
internetautomar's Avatar
mod or sell?
Lack of sufficient lubrication.
Probably a flaw in the design, very common on fords.
Old May 21, 2004 | 10:12 AM
eric93SE's Avatar
If you plan to fix that tranny again, I would replace the solenoid pack. You might have a bad line pressure solenoid.
Old May 21, 2004 | 12:45 PM
sbe9930's Avatar
The trans cooler in the radiator might be plugged. Lubrication oil is feed thru the cooler. The cooler are known to plug up limiting oil supply to the gears.
Old May 22, 2004 | 05:21 PM
Scope's Avatar
Im izz sexay
Our radiator does a bad job, if any at all, of tranny cooling. Best bet is aftermarket cooler (only 75 shipped)
user 11122324
42
Jul 18, 2022 03:35 PM
Pied
Sep 26, 2015 03:29 PM
