Throttle Body Cleaned but air filter lower?
I've just cleaned my throttle body and it is pretty simple, I thought it would've been harder so I'm pretty happy with it. I notice a better response when I press the gas but only below 2500 rpm but I don't mind, I now know that my throttle body is clean and I'm gonna check if it helps my gas mileage or not. There's only a lil thing that is bugging me, after I reinstalled everything, I notice that the air filter (ractive cone) is now sitting on the bottom part of the air box, if my memory is good, I remember the filter being like half or an inch above the box am I right? And the maf and oil separator now seems to be a bit loose, I can lift it maybe an inch or so, won't that be bad if I get bumps and the air filter lifts and bumps back on the box?
you can adjust the direction of your midpipe by adjusting the position of the hose, and then clamp it down hard so it won't shift around.
a lot of people had problem with the location of JWT filter cuz it's so big. the filter often gets scratch by the battery tie-down. i just simply adjust the hose and change the direction of the JWT filter. now it sits nicely between my drop resistor sensor and battery.
vingodine
45
May 21, 2016 12:46 PM
homewrecker
Aug 24, 2015 08:56 PM
kirkhilles
Aug 8, 2015 10:53 AM
