Intermittent audio issues + Armrest Console
1. This is frustrating. Every now and then my rear deck/speakers would cut out and only the front ones will work. Then all of a sudden they will power up. It's random and I can't reproduce it. I checked the connection(s) to the sub and they seem good.
Actually it sounds like the rear speakers are dead too but if you listen closely there is a faint sound coming from them. Almost like a super low output. And then it would all kick in back to normal and eventually die down. And it will repeat. It can be minutes or days between each cycle.
Ideas?
And while posting i figure I would save the org some server load and combine two posts into one:
2. Does anyone know how to remove the center console (the one with the armrest)? I unscrewed the screws, removed the shifter bezel but it wouldn't move. It shakes like it's loose but there is something holding it still. I can't see anything but if it was a clamp it should have come loose with the force I put on it. How do you take it off.. I am sure it's simple once you know the trick to it.
thanks guys
Ideas?
thanks guys
I seem to be having the same problem with mine. I notice the subwoofer fading the most. Sometimes I start it up and it's all good. Other times the sub is a no go! It is very annoying....please help .....thank you!
AaronL
Nov 15, 2020 11:52 AM
mikeg75
Nov 30, 2015 05:12 PM
RWCreative
Sep 21, 2015 11:01 AM
johnaschon
Sep 14, 2015 04:29 PM
