Water cooled turbo guys.
Old Jun 22, 2004 | 11:11 AM
Turbo95Max's Avatar
Turtle turtle... Moderator
hey
anyone got pics of the way you ran the water lines going to and from your turbo? i have rubber lines hooked up and their starting to leak. lookin for a better wayt o do it. thanks
Old Jun 22, 2004 | 12:14 PM
slimer's Avatar
A couple of Blaxxx's? Lawls.
does your turbo have fittings that can take ss line?
maybe welding a AN fitting on one of your end tanks will let you convert to ss.
Old Jun 22, 2004 | 12:20 PM
Jeff92se's Avatar
I'm needing a caw
You using barbed fittings? They shouldn't leak. I guess you can conver to some type of -AN fitting and use a compression type fitting for rubber or SS braided rubber.
Old Jun 22, 2004 | 09:31 PM
Turbo95Max's Avatar
end tanks?
wut you talkin bout? im talkin bout the turbo itselt.
Old Jun 22, 2004 | 09:33 PM
Turbo95Max's Avatar
yea i have barbed fittings. i tapped off some bypass rubber hose near the front of the motor and its a bigger size so i used this ghetto size down thingie ma bober. i would like to swtich to AN fitting but havent had much luck finding fittings. or maybe i can run the water lines from somewhere else.
Old Jun 22, 2004 | 09:40 PM
Jeff92se's Avatar
I'm needing a caw
Hmm how about using the water feed line to the TB? You could grab it before it gets to the TB. That should be a similar line size. DanNY gave me a great source for fitting etc.. I'll post it tomorrow. Can't you use a brass barbed fitting from Home Depot or something? Or is that the wrong size?
Question. I do believe you use a scavange pump right? Brand? Tilton, Mocal, Westech? Most places have them for $190-ish. Any ideas where to get one cheaper?
Old Jun 23, 2004 | 07:28 AM
Jeff92se's Avatar
I'm needing a caw
Here is the site:
http://www.anplumbing.com/
Old Jun 26, 2004 | 12:43 AM
Turbo95Max's Avatar
cool, thanks
i was lookin through that site and there is so much info on there. im so confused...ugh, i juss wanted to convert the fittings to AN and get adapter to convert tubing to AN...so complicated.
Old Jun 26, 2004 | 07:19 AM
slimer's Avatar
im going through the options of AN line for my fuel return right now too. jegs seems to be the least expensive
Old Jun 28, 2004 | 09:01 PM
Jeff92se's Avatar
I'm needing a caw
Any info on the Scavange pump?
Old Jun 29, 2004 | 07:52 AM
Julio's Avatar
hey
Although Jeff has a good point on getting that TB line, another idea might be just to tap it from the coolant plug on the block, cause its already threaded.
Old Jun 29, 2004 | 08:38 AM
DanNY's Avatar
Ad·min·is·tra·tor
cool, thanks
ok let's make this easy...what's on there now?
NPT or metric thread?
If it's 5/8 then get a 5/8 NPT to AN6. run a 90/120 degree AN6 swivel off the turbo so it'll clear whatever you have to.
bring it up to where ever you have your coolant feeding to and from...(heater hose/piping is also a good area). you can get a econ-o-fit hose end w/ the worm clamp and clamp it on there if you're on a budget.
if you have a 5/16 tube then you can get a compression 5/16 tube and slap on a 6AN hose end to that. if you want to play around w/ it you can get a tube nut and a flare tool and bring it out 37 degrees and it'll work also...you'll need a AN6 male union for that.
PM me or post what you have. I'll help you work it out from there. ALSO you do not have to use braided hoses. Earl's makes a nice rubber hose that works quite well esp for coolant set up. (yeah i know my plumbing)
Old Jun 29, 2004 | 08:39 AM
DanNY's Avatar
Ad·min·is·tra·tor
true...but it might be cooler if you're bringing it from the TB. the block gotta be nice and hot.
Old Jun 29, 2004 | 08:46 AM
Julio's Avatar
True indeed.
Old Jun 29, 2004 | 08:53 AM
DanNY's Avatar
Ad·min·is·tra·tor
Here is the site:
oh Jeff...they decided to raise some of their prices...they used to be A LOT better but now Jegs/Summit are pretty much neck to neck w/ their prices on fittings now.
I do have to say their selection is better than the others...but if the item is on backordered...good luck.
tarun900
19
Dec 20, 2021 06:57 PM
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
BobTX10
Oct 7, 2015 08:43 AM
