FrankenCar catback & Stillen rear valence question
Installed Frankencar Carback last night, it’s a very well made exhaust, but the rear tip sit inside the rear valence…doesn’t stick out far enough. I drove the car last night after the install and the rear valence was so hot you couldn’t touch it. My question is I know some of you are running this set up anyone had a problem with it burning the valence?
Do you have pics of this? It's hard to tell in the angles used in pics on Frankencar's website.
I would think that the heat coming off the tips would cause some discoloration of the paint over time.
Originally Posted by MAXINXS
Harmbone2k2 has the Frankencar exhaust. I think he had to move some of the exhaust hangers or something like that for it to work for him. Maybe he'll chime in.
I hope he does, because I can't be the only person with this problem.
I have pic but no way to host them, on a good side note the exhaust is beautiful every piece of it. Is very quite, at ideal it sounds like a stock 350Z. Once the car warms up I no longer hear it. My Injen intake is louder that the exhaust. The only problem is the tip don’t extend pass the Stillen rear valence, It gets so hot after about 15 min of driving you can touch it. I took it to three exhaust shops over the weekend and no one wants to touch it
I talked to Harmbone2k2 about this issue. He said that his bolted right up and fit perfect. All he did was tighten the exhaust hangers to make everything a little more sturdy. I don't see why one of the muffler shops in your area couldn't add a piece in and extend everything out. Good luck.
Yea but does he have the Stillen rear valence? The exhaust shops are saying there is no place to extend the piping without having it affects other parts of the system. They’re afraid that it will touch parts of the underbody & vibrate
I wouldn't lower it, you'll end up banging it against the axle or suspention when you go over bumps.
The best bet may be to have the tips cut off the muffler and have them add some pipe to extended them back some. If you end up doing that get some advice as to where to go in the SE forum, you don't want some tool doing this you want a very good welder.
They don't want to mess with it because it's stainless steel.
Get a measurment of how much longer you want it and start from there, we'll find someone to do it. Jay, Jason, Bags... someone in the Atl group knows who can weld SS. You may end up having to use new tips but it's better than F'ing up your valence.
In the mean time I'd swap the stock muffler back on.
Originally Posted by 2k3TitaniumSe
Check 2k2whitemaxi's site. He has the Stillen rear with Frankencar. They are pretty spaced out though.
Dman1989
19
Aug 17, 2015 03:44 AM
MaxStock
Aug 14, 2015 10:03 PM
MaxStock
Aug 14, 2015 09:59 PM
MaxStock
Aug 8, 2015 01:18 AM
ViciousVQ30
Aug 5, 2015 05:40 PM
