Check engine light come on, was told it was MAF sensor or oxygen sensor if not both
Old Jul 2, 2004 | 06:24 PM
jchris's Avatar
Car jerks some times only happens when check engine light is on.
was told could be oxygen sensor or MAF sensor , seems as though light goes off once oil is changed sometimes.
where is Maf sensor located ( mass air flow sensor) where to purchase and how to change do dealer have to reset anything. 2000 max 6speed
thanks for any type of info.
Old Jul 2, 2004 | 07:55 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
have the code pulled with a diagnostic tester. that way you can pinpoint what is failing instead of just guessing. oil change is probably just a coindence but my guess is the coils. 2k's and early build 2k1 have a very high rate of failure and can cause jerking when the engine misfires. also, are you sure you have a 6 speed in a 2k?
maxinout93
Aug 20, 2015 02:17 AM
beboski
Aug 16, 2015 05:23 PM
Flores94
Aug 11, 2015 12:53 PM
bassmann
Aug 3, 2015 07:53 PM
