need part # of inner and outer tie rods
can't find the # of inner and outer tie rods need them cuz i found a better quality type but not made for the max made only for sky's sentras and 240sx and want to compare to see if any of those can be used on our cars
"The rubber bush of the tension rod has been replaced with pillow ***** (spherical bearing) in all TEIN Pillow Ball Tension Rods. To eliminate tow change through compliance on acceleration or deceleration and allow only for vertical movement by the lower - arms. It also reduces the roll at corners and creates quicker steering response. In addition, the wheel alignment (caster angle) can be set through adjustments"
link
link
I'm looking at F.A.S.T right now and they have nothing about tension rods or tie rods. Looking at the suspension diagrams and there is nothing resembling your pictures. They either have a different name or I don't know what.
Does anyone know how to change a tie rod? Is it really simple or complex? I had my car alligned and balanced and was told my tie rod needs replacing. Is there a write up anywhere....or could someone post the haynes? Thanks!
Mar 12, 2020 12:06 AM
6spd4dsc
Mar 4, 2016 05:19 PM
MikesChevelle
Sep 7, 2015 09:11 AM
JoshG
Sep 5, 2015 10:10 PM
