K&N Filters Work?
You bet they do!
I just got one this week, and I'd say conservatively I burned up a good 1/4 of a tank gunning it from the line and going WOT. 20 Min ago I just filled up 17.02 gallons and my odometer read 511.5 miles on that tank!
got a drop-in
I like it. It may not provide any tangible gains, but I still liked it. It's probably a placebo effect, but the engine sounds freer to me. I didn't want to deal with the cons of the cone intake or CAI, so I just went with the drop-in.
K&N's performance gains,
I have heard of several dyno tests performed with just a pop in K&N filter, the results of both tests were the same,there was a 4HP improvement,so yes your engine does breath better. As for gas mileage I would not expect much of a improvement maybe a Gallon or 2 per fill up.
4hp, not too shabby
I just ordered my drop in today. The stock air filter needed to be replaced anyway and I wasn't ready to get the Pop charger so the drop in will have to do for now. We'll see what happens.
Re: got a drop-in
Just the drop in
This is from my own butt dyno, however from what I can tell before on the freeway at 3000 RPM's I was doing about 70-75 MPH. Now at 3000 RPM's I go 80-90 MPH. I am getting way better gas mileage. I replaced the clean stock air filter because I am planning on doing the OSCAI this weekend, and with just the drop-in I have noticed a HUGE difference. Am I just reading too much into this, or has anybody else received similar gains with just a drop-in?
Can't wait for the OSCAI!
Originally posted by straight six
I have the drop in filter and I have gained about least 3 MPG on average when I drive responsibly. I don't know about any performance increase but it does give the engine a slightly louder growl above ~3K.
How much was the drop-in? I bought my cone filter alone for $39 @ Autozone. Thought I got ripped, but anyhow. For performance, my motor spins like crazy up top, which I wanted more than down low, because I'm still having trouble launching it from a roll these days because of Remington tires. As for music...well, you'll have to hear it for yourselves past 4K. Up to now, I thought that RX-7's had the sweetest motor sound, and now, it does sound like a small block V-8 built to rev.
Stratteo...question....when you hold your K&N filter to the light, can you see small pin holes? I cleaned mine the other day and saw small holes. Was just wondering if that was normal on a new filter or whether there is a problem with mine. I don't want to use it if the holes aren't suppoesed to be there.
Originally posted by strattao
You bet they do!
You bet they do!
Originally posted by 96max
The drop in was about $90 CND.... so about $60 USD.. i think i got ripped...At least you get a performance gain you can feel =).... me.. well just htat i don't have to replace this filter for a long time... just clean..... anywayz, is your's just a generic filter? or the JWT/Stillen pop charger?
Re: Just the drop in
Re: Re: Just the drop in
Originally posted by emax95
Buahhahaha! Your out of mind dude. Your are still doing the exact same RPM's at 70 as you did before. Put it this way just because you add a few HP your gear ratios don't meraculasly change too! I wish that was the case, I figure with your logic my car could do 95mph in 3rd and be only at 4K rpms hehe. Your RPM's are always going to be exactly the same unless you tinker with your gear ratios.
No offence, emax.
Re: Re: Re: Re: Just the drop in
You mean "horrible"?
"Speling" and "offence" are both incorrectly spelled, also.
I ran a drop-in K&N for about a year. The reason it feels nice is that it flows great when it's NEW(clean). But after a few thousand miles, it didn't feel as good or sound as nice. Although the filtering ability stays right up there when it's dirty, it's my opinion that the K&Ns don't flow as well when they are dirty.
So instead of cleaning them at 50k or whatever K&N recommends, clean/oil them twice a year or every 5000 miles or so.
Originally posted by goldmax
Strattao...question....when you hold your K&N filter to the light, can you see small pin holes? I cleaned mine the other day and saw small holes. Was just wondering if that was normal on a new filter or whether there is a problem with mine. I don't want to use it if the holes aren't supposed to be there.
I paid $45.95 + tax at AutoZone for it, and I highly reccomend it to anyone that is wondering.
i put one in about year ago and the thing i noticed was throttle response. before i had the k&n if i were to just blip the throttle i wouldnt get much but now wiht the filter when i blip the throttle its much stronger it like throws u in ur seet other than that i havent noticed anything
You bet they do!
You bet they do!
Great! Thanks for checking! Just wanted to make sure my filter was "normal"!
Yes, I just looked, and there were teeny tiny holes. Not big enough to cause any problems by letting anything through that shouldn't be there.
Ok exactly what is the K&N filter and where can you get it? Sounds pretty decent. Im new so any specific details about this would be great. Thanks and im trying to learn enough to stop asking all these questions. Thanks again
You guys gotta realize that part of the effect you're feeling is the fact that your are going from a dirty filter to a clean one. The real fair comparison would be to test a cleann OEM filter against a clean K&N.
DW
DW
Does anyone have the model number for this filter? Or do they differ for the different years. Say I went to Auto Zone to look for one what would I ask for? Just a K&N filter or what? Im just curious. THanks for any help in advance.
I have to agree...
DW
DW
I purchased the ractive heat shield filter from Ebay. I got it at a great price, $25 with shipping. I noticed a difference right of the jump. I swear when I put it in reverse I was flying out and I didn't even put the foot on the accelerator. THE FILTER IS NOT LOUD AT ALL. I was impressed by the engine's baby v8 growl. Get one on ebay. Everyone who has road in my car has noticed a difference also.
K
K
anybody else got any good stories just by adding a filter?
I can't wait to do more!
MODS! MODS! MODS!
Get one of these filters!
MODS! MODS! MODS!
DW
DW
Originally posted by rll96se
Actually I replaced a month old filter. But I admitted my gains are barely noticeable. It still has to give me a little more flow than a stock/Autozone filter, right?
IMHO the K&N may or may not give any noticeable power. But, I think the advantage is that you clean it instead of replace it...saves money.
I've had mione for 100000 miles now...almost exactly. I've cleaned it a total of seven times.
50 (for filter)
20 (for two recharger kits, I could have gotten away with one...but I share with others)
A total of $70
Seven stock filters would be 7x15=$105
Thats why I like it.
50 (for filter)
A total of $70
Where on EBAY
K
K
Can you post a link to this heat shild filter on ebay?
Re: Where on EBAY
Originally posted by ajaffee
DARTHSWAN -
DARTHSWAN -
http://cgi.ebay.com/ebaymotors/aw-cg...6&tc=photo6764
Van
So if you tow a heavy load, your RPMs will increase at the same speed as with a normal load. Same with certain types of tires (like studded ones). However, you are correct in that you cant make your RPMs decrease for a certain speed unless you change the ratios. Nor can the filter itself allow you to go faster at the same RPM.
Originally posted by Matrix
Actually man, your RPMs CAN change even if you have not messed with gear ratios. RPMs are not fixed to certain vehicle speeds, they correspond to ENGINE speed.
jerrod99_se-l
Aug 27, 2015 08:27 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
kirkhilles
Aug 8, 2015 10:53 AM
