Cold Start Idle Problem
When I cold start my car, the idle speed is lower than the speed when it's warmed up. Cold start idle speed should be faster than normal, but mine is lower. The colder it is outside, the slower and rougher the idle. Since it's summer now, the idle is slightly below normal. When stopped at a light, before the engine is warm, the idle is rough as well. In the winter, this problem is obviously much worse, with idle speed being maybe 300-400. It feels like the car barely can even stay running. After driving, the car will warm up as usual, though.
The car will idle slightly high--around 1000--after it's been warmed up and then sitting for a few hours, so the engine is warm, but not operating temp. I don't feel like this is a particularly serious problem, the car's been doing it since I got it 3 years ago. Nevertheless I would like to fix this problem.
Thx
P.S. My normal idle after the car's warmed up is ~750-800rpm.
Thx
I had this exact same problem just a mere few days ago. So yes, along with what Sarin said, try doing the repair of the Air Regulator located in the sticky. I did that and it solved my cold idle problem and also solved my 500RPM drop when turning on my AC.
Niku, my car occasionally does that too, sometimes worse than others.
Zellix, sounds like the same prob.
I'll you guys know how it went as soon as I get around to fixing it. Time is scarce now that I actually have a job (GASP!).
ugh they are expencive buggers, i'm going to see if i can do a transmission pan gasket and filter if theyre going to have it out, and i'm going to replace a few things why they have it out...i can pop in after hours and do some stuff my self
if its not obvious to any one they are pulling my engine to work on it not like any of you give a damn though
tsi6001
Oct 3, 2022 10:23 PM
kjlouis
Nov 24, 2018 06:09 AM
kirkhilles
Aug 8, 2015 10:53 AM
