Performance Fuel Injectors
I have a 92 Nissan Maxima Sohc, does anyone know where I can buy a set of performance fuel injectors for it. Ive got 2 injectors that are bad and I just want to buy 6 new ones. I only found venom and they want over $600 for it, and if i have to replace them I want aftermarket injectors, not OEM. That's for the help.
Why do you need aftermarket? Do you have a turbo that is maxing out your stock injectors? I see no point in going aftermarket.
just get 2 used injectors from an org member or a junk yard and be done with it. if you spend anything over $100 on replace those 2 injectors your throwing money away that could be put to good use somewhere else
i would trust a used injector over a refurbished one anyday and new injectors or just rediculously expensize, i mean even with your discounted rate the injectors are still $105 a piece so as long as there resistance is within spec id think for 1/4 of the price or what ever would be a much better investment but this is just my opinion so he can do what he likes
But the question is how long will the used ones last?
1 day? 90 days? 2 years?
You don't know.
The new ones are of the updated design and less prone to failure.
and yes I'd trust a rebuilt one as far as a used one.
You don't know.
Venom started out as Python Injection. They take OE injectors and refurbish them. They do a great job, but you don't need to spend that kind of money on injectors. Get 2 used injectors and have them all cleaned and balanced and you will end up with the same thing as the same size Venom injectors.
injector replacement
listen man, i had injector 6 go out on me I replaced it with a python OE replacement injector and it works just fine. BTW I paid roughly 80 bucks and I got back 12 bucks when I returned the damaged one. SO in total 68 bucks for a refurbished OE injector, if I may say so its not bad compared to the (take it without vasline) prices at the dealer....
I would say that any local aftermarket/autoparts store can get these for you...
If the price is higher where you go, just tell them you priced it out at 7683 buck or so...
jae
jae
jmlee44
Oct 2, 2022 02:13 PM
