Oh My Good God...My car is FAST Again!!!
Finally!!!!!!!! Sorry but I am so happy right now
After everything I posted i did the fuel cleaner, air filter cleaner, spark plugs, oil filter change, throttle body cleaning, then today i got the MAF and put it in and nothing really happened then I took out my bypass valve and just put a regular boot on and then reset the ECU and MY GOODNESS....when i reconnected battery and went out for a drive....MY CAR IS BACK AND BETTER THAN EVER....first off forget the bypass valve bc my intake is soooo much louder and throatier without it ....then that sluggishness i tried to explain was TOTALLY gone and it revs so smooth and fast now through the entire powerband...no lag at all anywhere ...it's like I have a new car. :-)
moral of story...u have same problem I had??? (SLOW car thread a page back)...get a new MAF and reset ECU
I think my MAF is on its way out, car does not move untill i hit 4000 to 5000 rpm, i just had an oil change done, and the mechanics did not tell me anything was wrong. but i have this gutt feeling the car is not running up to performance. I may reset the ECU then see if it continues to be slow, how do i clean the bypass valve, i have a stock air box and stock filter.
sounds like the problem i had....get the maf, reset the ecu, and hope for the best...i'd bet that's the problem but don't hold me to it...i'm partial towards the MAF now bc it made my car come to life better than ever. :-)
Thanks, another question did your gas mileage suffer while your MAF was shot to hell? and how did you clean the bypas valve? do i have to clean it i have stock airbox? My car gas mileage is perfectly fine tho, i think its fairy good right now.
yah i can already tell the gas mielage is doing better...mine was real bad but i also haul everywhere haha....anyways...bypass valve is not stock, i put it in with my cool air intake to prevent hydrolocking the engine if driving through a very large puddle way too fast...i think you mean to say throttle body and you can do this by removing the throttle body and cleaning it with carbon cleaner that costs like $3 at autozone or somehwere ...or you can be lazy like me and just disconnect the air box from the throttle body and just spray it in and wipe down with a rag...i got throttle body cleaner for like $1 at Autozone and it tells you how to use it on the back. hope this helps
Originally Posted by Whtmax'01
If the MAF is not working properly should the check engine light come on? Also any way to check how well MAF is working using a voltemeter?
Its funny how I always tell ya guys its the MAFs that make the 00-01s feel slow. I am on my 5th MAF right now, and have 2 spares. Sold my 3rd spare to Stardust on the .org here cause his 00 ran like a stock 4th gen auto. 22680-AD210 is the new MAF, its not the whole assembly- just the sensor part itself- I dunno the list price on them, I get em for way bellow list.
Mike Jez.
01 Max 5spd.
86 Audi Coupe Quattro Turbo.
93 G20 Turbo.
Mike Jez.
01 Max 5spd.
93 G20 Turbo.
Originally Posted by 98coupev6
Kruppa, the maf sensor u got is it this part # 22680-2Y001? i'm looking into getting one also for my 00...
Yup, that is the one that i got....other ppl mention about just getting the sensor but i got the whole assembly just for peace of mind
the better way to reset your ecu is by going straight at it to the right of the driver's feet. there is a little flathead you turn one way and hold to reset. this also gives you codes you can cross reference to nissan to see what sensor is going off. the dealerships have a scanner called.... i dunno right now that diagnosis your problem or codes properly
Mike Jez.
01 Max 5spd.
93 G20 Turbo.
Mike Jez.
01 Max 5spd.
93 G20 Turbo.
just reading this makes me think about how slower my car feels lately as well.....but im a noob when it comes to engine fix. Where can i order this part? and about how much? is it hard to replace?? i notice this sluggishness the same day my check engine light came on. thanks in advance for answering my noob questions.
also if i just disconnect my neg batt over night and plug it back in the morning will everything be ok? or should it be shorter? thanks.
Originally Posted by GoGo BZB
OK heres my problem that started on Friday. I turned my car on it reved to 2000rpm then starts to bog out. Itried to rev it up but it would not go past 2500rpm. Could this prob possible be my MAF? I have a 2k1AE.
FAIL-SAFE MODE
When the malfunction B is detected, the ECM enters fail-safe mode
and the MIL lights up.
Detected items Engine operating condition in fail-safe mode
Mass air flow sensor circuit Engine speed will not rise more than 2,400 rpm due to the fuel cut.
you need a MAF, you can't go more than about 15-20% throttle or the engine will bog. Also one more thing all of you are forgetting- the ECU needs to be recalibrated for the NEW updated MAF. I lost 10WHP accross the board on the dyno with the old program. I have the Consult printout with the correct ECU broadcast code for the program. Stardust- how is your car since the ECU reflash we did a week ago ???
Lakersallday24
Jun 16, 2019 01:35 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
yat70458
Aug 3, 2015 01:16 PM
Finally it's back......Let's race :wink, wink:
