Is the Front Strut Brace worth it?
I'm thinking about getting the front strut brace for my maxima but I had a few questions about it. First, does it matter which one you get and from where because I see prices ranging from about $50 on courtersyparts.com to $180 on stillen.com for my 03 GLE. Also does it really improve handling that much. If so then in what way? Any input, suggestions, and/or pics would be much appreciated.
You need to team it up with an RSB and you will feel the difference. Go even further with Illuminas and Eibachs or maybe even JIC D2Racing or Tein coilovers.
It's a good start. Just build on it.
Basically a cosmetic mod. Many can't tell any diff at all. I would almost guarantee I could put it on and remove it and you'd never notice. I'd suggest spending your $ on a RSB and springs/struts instead.
I disagree about it not being that helpful. I didn't feel like spending $150 on one (Stillen) so I went with Otto ($52). It has greatly reduced the torque steer on WOT from a stop. It was well worth the money.
Originally Posted by XGaSpAcHo
....does it really improve handling that much. If so then in what way? Any input, suggestions, and/or pics would be much appreciated.
That said, if you lower your car through stiffer springing, add cornering capability thru RSBs, bigger/fatter tires, etc, and/or you drive hard on rough roads, the FSTB will tighten up the car a bit by reducing what little flexing remains in the Gen5's front chassis structure.
Plus it looks good
If your drive your car like granpa you wont see the difference you will feel the difference when cornering or changing lane at higher speed. I think the FSTB with the RSB it worth the money for the " sporty driver"
AA
AA
I got a very cheap polished one off eBay, IIRC like 30 or 40 sheckels. It looks good, and I figure it's a bit better than NOT having one. I can feel a very slight stiffening upon hard driving, and as said above reduced torque steer. Well worth the low price I paid
sdotcarter
Sep 2, 2015 09:53 PM
MaxStock
Aug 14, 2015 10:01 PM
