Replacement for trunk cover (aka spare tire lid)
Does anyone know if there is good replacement for this? Mine is all warped and now I sport a crater right in the middle of my truck
This is really killing me since I can't put anything in my trunk straight.
I would like to go aftermarket since I know the stock one will warp again. Does anybody know where I could get one or make one?
Thanks!
This is really killing me since I can't put anything in my trunk straight.I would like to go aftermarket since I know the stock one will warp again. Does anybody know where I could get one or make one?
Thanks!
what is MDF?. I have a friend who owns a screen-printing shop. when i get some time, i'm going to get some "plastic-cardboard" and reinforce it with some small aluminum braces (to be custom made) the plastic-cardboard looks about like the same stuff that is covering the inside of your trunk-lid, but minus the spray-on carpeting, or whatever that stuff is...
Mine caved in when i put my system in the back. I then took the carpet out that covers the trunk floor, and used it as a template on a piece of 3/4" plywood... the piece of wood is one giant piece, and worked GREAT! however, i sold my system, and now i have the piece of plywood lying around... but there is always that extra weight factor too... my system and the plywood set the backend down pretty good... mostly the system.
It just depends on what kind of heavy stuff you're going to be sitting in your trunk (in the end). Whether it be a system, a bunch of groceries, or even your local dead corpse, you never have to worry about he 3/4 caving in... ;P
Here’s some more Home-Depot modding for you HDM Freaks
Where do can you find MDF? Would Home Depot have these? Also, I don't have any place to work on anything like this. Let alone a recipricating saw. Does Home Depot or anywhere else cut a custom shape if you bring a template?
Also, I was wondering if there is plug-n-play solution for this.
Thanks guys!
Thanks guys!
Thanks guys!
Thanks guys!
I'm thinking of doing this myself, except instead of 1 huge piece, it'll be setup for easy access to the spare tire bay (hinged door cutout)....
after all, I have to keep my title as the home depot mod
haha
Originally Posted by irish44j
you could also use plexiglass or various other thin, strong sheet materials available at HD....jig saw is not very expensive....you can get a cheap-o one for like 20-30 bucks....or buy a handsaw (the type you use for cutting molding and wood trim) which will work too (it will take a long time though)...
haha
haha3/4" MDF, carpetted to match....
dang 3/4 mdf is kinda heavy. i used 1/2 mdf and used that carpet cover in your trunk as a trace, cut out the shape. see if it fits. then cut that puppy in half and put hinges on it so you can get to your tire....if you have sounds like me. the cut it right where the sub box ends.
Originally Posted by PoLo
as always, i need to jump in with "do you mean something like this"........
King_Ten_Ahead
Sep 30, 2015 04:27 PM
and do a write up may be ...
