Octane, facts and figures...What do you use?
Hey, what octane gasoline does everyone put in their Max? Are there any benefits to using higher octane, and does it hurt anything if you use a lower octane? I've read many articles on this subject and the general conclusion is, using 91 octane over 87 is not worth it. What does everyone think?
Unfortunately in the NYMA, the only AKIs available are 87, 89 and 93. Since Nissan recommends 91 or above, i always get the 93, but just to see what happened, I got the 87 once. The car doesn't stutter or miss with the 87 in, but it feels like you are driving with the parking brake up just a little. My gas milage went down about 30 miles a tank lower than it normally gets. The extra 15 cents a gallon really doesn't make me much of a difference.
Use premium for maximum performance
Originally posted by medicsonic
. . . it feels like you are driving with the parking brake up just a little. . .
Half-and-half
Unfortunately in the NYMA, the only AKIs available are 87, 89 and 93. Since Nissan recommends 91 or above ...
Not all stations allow you to change grades however. I have tried this before (by your suggestion) and have found that they do not allow you to push another grade button after you have selected your first one.
Re: Half-and-half
Originally posted by Daniel B. Martin
I fill with equal amounts of 89 and 93 AKI. That's the economical way to purchase 91 AKI gasoline.
-Custom-
Re: Re: Half-and-half
I used 85 the first time and 87 the second on a trial bases not intending to use it again. I then went to 91 and have been there since. The engine does seem to run smoother with the 91 than it did for the others. Take Care
probably not custom because the car is always moving and the gas is swooshing around... it doesnt just sit still if it would seperate it would probably mix it up from the movement, but who knows i just go with 93 all the time
Originally posted by JC
I use 93+ using a 87/89 octane fuel my JWT ECU will not perform a its best, and every ECUs and Chips manufactures recomend the use of a premiun gas.
Two transactions
They mix perfectly
Originally posted by CokedOut
That's an interesting solution, and in theory it sounds good but...I'm no chem major, but if you put two different octanes in the tank, one would have to be more dense than the other. Therefore, most likely the 93 octane would sink to the bottom and the 87 would be on top, creating a complete seperation in the actual gasoline. Then wouldn't the car use each gasoline octane seperately? Like it would burn the 93 octane first, then go to the 87? Somehow this dawned on me from the 10th grade so i'm probably a little off on my facts, but is there any truth to this?
-Custom-
-Custom-
Some fueling stations had (or still have) multi-blend pumps. The customer cranks a dial to select the desired grade of fuel. He can select 87, 88, 89, 90, 91, 92, 93, or 94 AKI fuel. There are only two underground tanks, one with 87 AKI and the other with 94 AKI. The pump mixes the fuel to suit the customer's demand.
I always use the highest grade available at the particular gas station. I used 87 octane before and like the others said, it did feel slugish. Once is good enough for me. Only problem is that it drains my wallet a bit using high octane gas.
Originally posted by chandos
Has anyone tried using an even higher octane like 109 or 119? There is gas station where I live that offers both. Does anyone know if that is too high of an octane and would have any detrimental effects on the engine?
Originally posted by SB97MAX
Is 93 octane just in certain places? I live in Colorado and have never seen 93 before. The highest is 91 here.
I use 93, nothing else. I used 87 a couple of times, and the engine knocked. Nothing major, but when I would rev the engine in neutral, just before it would rev up it would knock. Using 93 solved the problem, and I noticed a considerable increase in performance. Geez I really thought all that was a myth.
I've been convinced. I'm going to start dumping 91-93 octane in the tank and see how that runs. Like I said, I read that the difference between 87 and 91 octane is virtually nothing, but i'm going to give it a go on the next tank. Thanks for all the input.
_CUSTOM_
_CUSTOM_
In areas of high-altitude, such as the Rockies, you can use slightly lower octane due to the thinner atmospheric air, which acts to give the gas a pseudo "anti-knock" index--thus using 91 octane in Colorado will be like 93 octane at sea level. Nonetheless, although you have a higher "pseudo" anti-knock index at high altitudes, you're still facing the fact that you have thinner air, thus your engine will develop less power than at sea level, and there's nothing you can do when you're up at high altitude. But then again, every car up at high altitude will lose power in the lower oxygen environment. I may be wrong, but I've read somewhere (Motor Trend, I think) that you lose about 3% maximum power per 1,000 ft. gain in altitude.
Most manufacturers will let you know which level of octane in gas to use, and they're not doing it just to help out the gas companies. For those at high altitude, you can use slightly lower octane and not experience engine knocking problems. In any event, use premium grade in the Maxima for optimal performance.
Instead of messing with pumping two grades of gas at one stop, a person can fill up with 93 one time, then at 1/2 tank, fill with 89... Then, when it reaches 1/2 tank again, refill with 93... and so on... and so on... This will keep a -fairly- even mix of fuel in the tank. The 89 fillup will be a little lower than the 93, but still probably be just fine.
Personally, I don't fool with it, and use straight premium. Five cents a gallon for 16 gallons just isn't worth the trouble. For 80 cents, I'll use straight premium and not deal with the hassle. An extra dollar a week isn't worth the trouble of mixing the fuel -to me- .
It's your money, and your car. Do whatcha' want.
Good Luck!
Good Luck!
I agree with n2oMike, I don't find it worth the trouble to mix octanes. However, where I live (VA) 93 is 10 cents a gallon more expensive than 89, not 5. However, the Shell right down the street from where I work has premium discounted 6 cents a gallon on Tuesdays. So I make sure to fill up on Tuesdays, and 93 is only 4 cents more a gallon than 89. That's only 35 cents more for a tank of 93, than a tank of mixed 89/93. It's not really worth 35 cents to swipe the check card twice, and make two entries in the check book.
n2oMike....I realized you were saying 5 cents/gallon, because it's 10 cents/gallon different, but you're mixing half and half. Doh!
However, I have seen 5 cents/gallon difference between 93 & 89. I think it was near Minneapolis.
what kind of prices are you guys paying for premium? its 1.69 around here, it sux i remember when i could find it for like 1.17 a few years ago and when it was rising, 1.50 seemed like so much, i wish it was 1.50 lol
I pay 1.49 in atlanta. I remember 2 years ago it was .99. Damn I miss those days. But the gas prices are slowly creeping up. I only use Amoco. Question for you all, since BP has taken over Amoco, will Amoco gas still be used, or what?
K
sensitive
I heard that the VQ engines are sensitive. It's a high compression engine, making it sensitive to octane levels in fuel. I tried 92 plus 104 octane booster, and the car felt more responsive, and it increased 29 miles.
I'm in Boca Raton (south florida), we're still figuring out how to punch our god damn ballets...The gas stations are charging around 1.80 per gallon for premium, and 1.62-1.64 for regular. If you drive 5 minutes to Broward county, you can find prices 10 cents lower per gallon. It's ridiculous, what they are doing is called something like "class-targeting" or "financial-grouping"...something like that. It is apparently illegal, and there are a few gas station owners around here that are actually filing suits against gas stations that are 6-7 cents higher b/c they are near million dollar neighborhoods.
doctorpullit
Dec 12, 2015 09:39 AM
Turbonut
46
Oct 21, 2015 08:28 PM
JoshG
51
Sep 21, 2015 10:41 PM
sdotcarter
Sep 2, 2015 09:53 PM
